My KMS P&P head
Old Jul 19, 2004
  #121
Green Civic's Avatar
Every time you put it on, does it come from the same spot? If it comes from the same spot, pull the head off and check that one spot. If it is at the same side, but different spots, flip the gasket, look at the gasket in that spot, and get a new one. IS there any pics you can take. Maybe we could help you out more. Try taking to a mechanic or honda about the problem. Maybe that know something we're, your, over looking.
Old Jul 19, 2004
  #122
jrock2324's Avatar
jrock2324 is an unknown quantity at this point
Same spot everytime.
Old Jul 19, 2004
  #123
Check it very carefully for smoothness. It has to be completely smooth with no bumps. Oh and did you put the bolts on in the right order? Also the guys that did mine said if a head bolt starts to squeak going in, you have to start over. My new bolts didn't squeak at all.
I'll take a look at the service manual to see if it says anything.
Old Jul 20, 2004
  #124
orso's Avatar
orso is an unknown quantity at this point
damn dude that sucks. hate it for ya.
Old Jul 20, 2004
  #125
Try calling honda. See what they recommend.
Old Jul 20, 2004
  #126
jrock2324's Avatar
I check it and it was smooth.
Old Jul 20, 2004
  #127
jrock2324's Avatar
I am taking my car to a shop in the moring.
Old Jul 20, 2004
  #128
Then you need new bolts--total of 10 for $10 each = $100. Sucks, but at least it won't leak anymore. Make sure you tighten them in the proper order. Get a new gasket as well, since the other one is bad by now.
Old Jul 22, 2004
  #129
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
Just a quick Q. What else would I need to install with my KMS manifold to make it work ? Mine is sitting in the garage for the last cpl. months, some people were saying how KMS manny sucked and how it was robbing engine of its power unless the you bored out throttle body. So is this still true or what ?
Havent been in modifing mode in the last cpl months, so im just getting back to it, any updates you can inform me about or how should I go about with this manifold ? I'd hate to waste something i payed 500 bucks for. Thanks.
Old Jul 22, 2004
  #130
It actually will cause you to lose power unless you're boosted. Taking out the IM will most likely involve removing the head, since there's very little chance of taking it out where it is. Then you need new gaskets, and new head bolts if the head has to come off. Not worth it for the loss in power it will give. Sell it to someone with a turbo.
Old Jul 22, 2004
  #131
djmota's Avatar
you CAN swap intake manifolds without taking off the head...been there,done that... But I would advise against it. You will just be losing power, I ran the kms manifold for about 6 months. When I switched back to stock it was like night and day. stock being much better. In my opinion the only way to possibly make it work would be boost, Or to modify it for NA I have been thinking about porting the ends of the intake runners on the inside of the box and shrinking the size of the plenum. Doing those 2 things should incease the velocity needed to make it do what it should. Sorry to say but it is a waste of all of our money
Old Jul 22, 2004
  #132
5PEED EX's Avatar
Aight, tx for the comments fellas.
Old Jul 23, 2004
  #133
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Any news?
Old Jul 24, 2004
  #134
jrock2324's Avatar
They cant look at my car until monday
Old Jul 25, 2004
  #135
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
i'm a newbie on engine mods and reading everything I can and I was wondering what you guyz are talking about when u say TB? thanx
Old Jul 25, 2004
  #136
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
throttle body...
Old Jul 25, 2004
  #137
jrock2324's Avatar
^^^^ what he saided
Old Jul 26, 2004
  #138
thanx! well I have another quick quesiton. when its all said and done with, on engine parts for our engine...like for an intake, pnp, throttle body, pistons, rods, valves, etc. to beef up our D17 how much HP are we talking (including exhaust) because i've got some money saved up and I dunno if its worth to spend all that money on beefin up a D17 or keep saving for a swap...but first off i wanna know approx. how much hp could our engines get with those mods i listed above. thanx
Old Jul 26, 2004
  #139
Hopefully I can get my car tuned on a dyno before winter. I have a port/polish head, and the TB is getting bored out in a week or so. Then I have vafc for air/fuel that needs tuning. It won't be much of a gain I think. Our cars are built more for low emissions.
Old Jul 26, 2004
  #140
jrock2324's Avatar
If u want real power u need to get a better ecu. I am thinking about getting the AEM ecu.
Old Jul 28, 2004
  #141
ponyman's Avatar
ponyman is on a distinguished road
What's the story on this one????
Old Jul 28, 2004
  #142
jrock2324's Avatar
Ok guys. The guy said I needed new bolts and cam seal. I will have my car back maybe friday. So I will let everyone know whats going on friday.
Old Jul 28, 2004
  #143
EManEX's Avatar
Great! so it doesn't have anything to do with the work done on the head.
Best of luck to you.
Old Jul 28, 2004
  #144
jrock2324's Avatar
yep. Nothing was wrong with the head.
Old Jul 28, 2004
  #145
djmota's Avatar
Woot, I called it !!
I am glad to hear that it was nothing too serious.
Old Jul 28, 2004
  #146
I called it too with the bolts. Should've gotten new ones from the start
Old Jul 28, 2004
  #147
jrock2324's Avatar
Yep. Both of u guys called it. Thanks for helping me.
Old Aug 3, 2004
  #148
ponyman's Avatar
So have you gotten it back yet, any reviews so far, what is going on????
Old Aug 3, 2004
  #149
Titleist71's Avatar
Did u found out y your car had the rough Idle?
I got thinking about that Gearbox....do you have an aftermarket flywheel? If so...getting a flywheel that is too light could cause your car to idle rough and stall out.
Old Aug 3, 2004
  #150
All I have is the head and few very basic mods like iridium plugs and hyper voltage system. All of which weren't causing problems before. The idle is actually on the very low end of the proper idle, but the head seems to need a higher idle to keep it going. Bigger ports=slower air flow=more air volume necessary. I'm hoping the bored out TB will help this. If not, I'm just gonna adjust the TPS until the idle goes up a little. All I need is maybe 100-200rpms more.
