My KMS P&P head
Old Aug 3, 2004
  #151
Green Civic's Avatar
Wow. Finally resolved. Hows the car running?
Old Aug 4, 2004
  #152
jrock2324's Avatar
jrock2324 is an unknown quantity at this point
I am getting the car back after work today. He had to adjust my valves too.
Old Aug 4, 2004
  #153
SomeDoodToo's Avatar
SomeDoodToo will become famous soon enoughSomeDoodToo will become famous soon enough
nice!
Old Aug 4, 2004
  #154
ponyman's Avatar
ponyman is on a distinguished road
the we expect a review tonight....capish(sp?)....
Old Aug 4, 2004
  #155
yeah tell us how it's working!
Old Aug 4, 2004
  #156
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Man I'm happy for you. It is a great feeling to have your car back after such a long time. Like gearbox said keep us updated on how it works.
Old Aug 4, 2004
  #157
jrock2324's Avatar
All I have to say is wow. From 0-80 is so quick . I did not go pass 80 yet but I will tomorrow . I am very happy with kms work . I cant wait to get the dyno done.
Old Aug 4, 2004
  #158
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
good luck man
Old Aug 4, 2004
  #159
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
when r u getting it dynoed?
Old Aug 4, 2004
  #160
jrock2324's Avatar
yep. I am trying to get it dyno soon. The guy said I had to wait 2 weeks because they are all booked up. Its going to cost 225 for the tune and the dyno.
Old Aug 4, 2004
  #161
I need to tune mine as well but never have the time. Are you getting the TB bored as well? I get mine Friday, so I'll tell you if it helps any. One thing I noticed is your exhaust ports aren't huge like mine (good thing). Dyno will be good, and it should feel even better after tuning. I'm assuming you have the e-manage or vafc. Good luck with everything.
Old Aug 4, 2004
  #162
Oh and also, is your header port matched to the head? You want the header ports to be the same size (or bigger) than the head ports.
Old Aug 4, 2004
  #163
jrock2324's Avatar
My tb is already bore by kms and I have a safc. The exhaust ports are the same as the header.
Old Aug 4, 2004
  #164
Looks like you're good to go then. Let us know what happens after tuning.
Old Aug 5, 2004
  #165
cwick187's Avatar
cwick187 is an unknown quantity at this point
Glad to hear that everything is running...If the P&P is done correct, you should feel it pull like you have described...I know I noticed a big difference after mine was done...How big of bore was done on your TB?
Old Aug 5, 2004
  #166
orso's Avatar
orso is an unknown quantity at this point
congrats. finally somebody didn't get screwed. can't wait to see some numbers
Old Aug 5, 2004
  #167
How much is that ^
And am i paying to much for my P&P (250)
Old Aug 5, 2004
  #168
EManEX's Avatar
^I don't know in your area but $250 is about what it goes around here. (P&P head)
Old Aug 5, 2004
  #169
For bored TB? I sent mine to maxbore.com for $105. It's coming back tomorrow.
Old Aug 5, 2004
  #170
EManEX's Avatar
^Sorry, I was talking about the P&P head.
Old Aug 5, 2004
  #171
jrock2324's Avatar
It was bore to 65mm
Old Aug 5, 2004
  #172
Do you know how much the stock bore is?
Old Aug 5, 2004
  #173
jrock2324's Avatar
I have know Idea.
Old Aug 5, 2004
  #174
jrock2324's Avatar
My rpms are jumping up and down sometimes. Why is it doing that?
Old Aug 5, 2004
  #175
Rough idle Probably caused by the throttle body. If you reset the ecu, it probably will go away after a few hundred miles of driving. The ecu needs to recalculate a/f ratios based on the increased air intake. If that doesn't work, I'm guessing something is wrong with a sensor on the TB. KMS should have pulled all those off when boring it, so they may have been put back a tad off. The TPS is the main cause of rough idle usually, but can be fixed by moving it up or down. Did be put screws on the TPS so it can be adjusted? The stock one has some rivets that can't be loosened. I guess you could always gently tap it, but be careful. Also it won't do much.
Old Aug 5, 2004
  #176
jrock2324's Avatar
It only does it sometimes. Like if I put the car in park it keeps jumping from 1000 to 3000. Up and down.If I turn the car off and start it then it goes away. Also the engine bay is very hot now. It only take like 20 sec in the moring for the temp needle to be at half. Before it took like 2 mins. But the car is not overheating.
Old Aug 5, 2004
  #177
I noticed that with mine, and I'm betting it's the header. It gets alot hotter than before, which is gonna hurt performance as far as hot air getting sucked in. It got down to 50F tonight, and my engine sounds completely different. More of a throaty sound, and it feels faster. Your problem sounds like a TPS, or one that just wasn't adjusted to factory spec. See if they put screws on it so you can loosen them and move it around.
Old Aug 6, 2004
  #178
jrock2324's Avatar
yep. Its alot more hotter under the hood. How do u adjust the tb?
Old Aug 7, 2004
  #179
I just installed mine and no idle fluctuations. Still too low though, so it shakes. You can adjust the TPS if kms put screws in yours. The stock TB has some tamperproof rivets.
Old Aug 7, 2004
  #180
jrock2324's Avatar
The place I took my car to said it can be adjusted. I am going up there now. The car bogs down on me like 3 times last night. I dont even have to give it gas for the car to move. If I let of the brake the mph go up by itself
