Lugnut stripped...
Old Jan 26, 2018
Slicer1989's Avatar
Slicer1989 is an unknown quantity at this point
Lugnut stripped...
My 99 Civic LX has a stripped lugnut, the shop tried taking it off and ended up stripping it... Not the lugnut itself, but the stud. It just spins in the hub assembly (Couldn't get it off completely) and now it won't tighten, so it's just floating around in the wheel... So my question is, what's the best least damaging way to get it off? Probably gonna have to destroy my hub cap and cut it off. But can I replace just the stud? or do I need to replace the whole assembly?
Old Jan 26, 2018
CraigW's Avatar
Re: Lugnut stripped...
Front or rear ?
Rears are straightforward on Hondas..... Fronts not so much.
Old Jan 26, 2018
Slicer1989's Avatar
Originally Posted by CraigW
Front or rear ?
Front passenger side. Forgot to mention that...
I gotta get that wheel off because that tire is just about ready to die.
Old Jan 26, 2018
CraigW's Avatar
Sorry for lack of help.... hope one of the mechanics will chime in. Honda made changing out the front studs less than simple though.
Old Jan 26, 2018
the fronts, most likely you will need to remove the hub to get them out... replace bearing while at it? and put new studs?
Old Jan 27, 2018
Slicer1989's Avatar
I got it off, It was backed out enough I was able to just put my 4-way lug wrench on it and break it off...
Old Jan 27, 2018
great!
normally, you would need to remove the hub
Old Jan 27, 2018
Slicer1989's Avatar
I'm gonna have to anyways, I can't ride around with 3 lugnuts forever.
Old Jan 27, 2018
a shop stripped my studs once too...
and did not want to take responsibility... took a year to find a shop that would actually take the job.
took two days for them...
Old Jan 27, 2018
Slicer1989's Avatar
The shop I went to wouldn't... They wanted to replace the hub, bearings, caliper, rotor and pads just to replace a stud they stripped... I told em to eat **** and take responsibility for what they did, and the guy was like that wasn't our fault, blah blah... and when the mechanic drove it around, here said even with me 1200ft lb tool wouldn't get it off....
Old Jan 27, 2018
If it jammed and stripped or broke during disassembly, the last person who installed (and overtightened) the lugnut is usually the person to blame.
However....some shops won't operate that way, some lack integrity, some egos won't allow some people to admit fault, and lack of understanding of basic mechanical principles causes many others to not believe they could ever be at fault.
If it's been a long while since the car was at that shop, or if you are a floater (one who 'floats' around to various shops, not sticking with a single shop) then they may balk at taking care of it because they can't be positive nobody else touched it since they last had the car....plus it costs them money and time.
So think carefully about who else could also have removed and installed the wheels.
Much of the time, a new stud can be installed without removing the hub from the knuckle and bearing. You sometimes have to be creative to get it done though.
Other times it's impossible to replace a stud without pulling the hub.....and I don't want to guess at what yours is like without seeing it up close first.
Old Jan 28, 2018
found it - there is a link to a DIY here.
https://www.civicforums.com/forums/1...eel-studs.html
some additional info from ezone here as well.
https://www.civicforums.com/forums/1...ease-help.html
K20me
Apr 16, 2004 10:41 PM
jiggerachi
15
Apr 2, 2004 03:05 PM
runner1738
Mar 14, 2004 10:40 AM
Aznnp77
Apr 28, 2003 09:09 AM
