correct lugnut?
correct lugnut?
i just went o get tires for my subzeros but they were reluctant to put them on my car unless i had the correct lugnut set, Zenki forged racing lug nuts work? i bought them used from a member, and sure if they work? do they and if not what are the correct ones?
thought so, but wasnt 100 % sure, and my tire shop didnt want to take a chance, they also asked for a number to call rota or something anyone have that? also the lugnuts say they are pre oiled, so should i not rinse them off with water to clean then?
Don't wash them, that'll take the oil off. Its just a thread lube so they go on smoothly. I know they fit because I've personally put them on. Dunno the number for Rota. The number you really want is Cosmic Marketing. They distribute Rotas.
yea i found there site but only had an email address, i bought the lugnuts used so is there a way to tell if they are still oil properly? and is there a way to clean them without removing that lube?
You can dunk them in water, just no soap. Eventually the oil would have worn off anyways. if you really feel its necessary, put a drop of a very light oil (household, don't use something like motor oil) in the nut then thread it on and off a couple times to spread it out.
Its a celebration bitches!
actually hes the one i got them off of, because i was getting some light 15's then the deal went threw so i never had a chance to use them. i never used them. and he said he only test fitted them, he has the valve stems
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Bruce2
Sep 21, 2015 08:01 PM
