HELP! Broken Piece Lugnut Screws On To!
Old Apr 16, 2003
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
Okay, here's what happened. I was driving somewhere and the steering wheel started shaking and making a loud noise. So I stop somewhere and see the I have lost 3 out of the 4 lugnuts on the wheel. Thank god I stopped in time. Now theres an advanced auto parts store right near by luckily. I buy 4 new lugs and come back to find that they don't fit my rim. So I use the spare tire instead. The OEM wrench doesn't work, so I have to go back and buy another one. I come home, and try to replace the wheel with the OEM wheel. As I'm taking the lugnuts off, one of them is stuck. I think that I tightened one of them incorrectly. As I tried to get it off, the thing broke! I assume this is not safe to drive on is it? What am I looking at replacing and how much will it be? Is this a definite mechanic job?
Old Apr 16, 2003
Weaponx12o's Avatar
wait, so the lugnut broke? why dont you just buy another one? try contacting the company that makes your rims. in the mean time, just put the stock wheels back on. sorry to hear you having these problems. hope you get them solved
Old Apr 16, 2003
flotsamm's Avatar
I'm assuming you mean the front since it started shaking real bad? Anyway, if you broke off a stud you can sometimes just get that replaced by removing the brake rotor and hammering out the broke one. Then buy a new stud and hammer it back in. If it cant be hammered in, then it may have to be brought to a shop and pressed in. Also, I think you can just buy a new rotor instead which will have all the studs already installed. Not sure, I'm sure someone will correct me if I'm wrong.
Old Apr 17, 2003
Slumpert's Avatar
Slumpert is an unknown quantity at this point
Studs sell for around $8-$20, way cheaper than a rotor.
NTB charged me $40.00 to replace a broken one in my Minivan, I watched them and it was stupid simple, He took off the tire, placed a metal pointy thing on the broken stud, whacked it 3-4 times with a rubber mallet and the stud fell to the ground. He placed the new stud in the hole, put the nut on, tightened it some, took nut off put the wheel on and tightened it fully. No idea if this applies to Hondas as well, but it prolly does.
Slump
Old Apr 24, 2003
MMILX's Avatar
MMILX is an unknown quantity at this point
I broke one in my old Sentra SE-R once. You basically remove the wheel, pound out the old stud, put the new one in, and a neat trick -- use the lugnut and tighten it to pull the stud into place tight. Of course this was done with an impact, but sure easier than having to pound it into place from the back side.
Old Apr 25, 2003
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
how do you guys break the studs? are your rims not hubcentric or something?
Old Apr 25, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
well, i think he cross threaded the one lug when the other 3 fell off and it put extreme pressure on the remaining stud which cause it to crokk thread ands broke when it came off. Very simple to fix.
Old Apr 25, 2003
I'm The Shit
oh, and it should be ok for a while to ride on with 3 studs but dont hit bumps hard or potholes.")
Old Apr 26, 2003
turboslug's Avatar
Super Hoser
Old Apr 26, 2003
MMILX's Avatar
Its called the overzealous, non torque-stick using retards at the tire place.
Old Apr 26, 2003
nightkids1's Avatar
Initial D!!!!
yeah, if you torque your tires down to much you will break them. i always redo mine when i get home from a shop. and use a torque wrench people.
Old Apr 27, 2003
MMILX's Avatar
Yeah, once those morons tightened the nuts so tight, I was standing on a cheater bar (yes, Standing!) and it wouldn't budge. The cheater bar was over a foot long, slipped over a 1/2in drive ratchet. And I'm not exactly a lightweight
Old Apr 28, 2003
slystad810's Avatar
$8-20 for a stud?? Last time I bought one at Autozone they were like $0.97 each!
ricer_em2
May 11, 2016 08:09 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
pilebuck13
Sep 21, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
redcloud
Sep 7, 2015 01:45 PM
