View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Nov 16, 2017
  #31
Re: Ideal oil temp?
IMHO an ideal temp for synthetic is the same ideal temp as conventional....just the syn will supposedly tolerate higher working temps before breakdown.
Ideal temp is hot enough---and stay at that temp for sufficient length of time--- to steam off or boil off contaminants-- condensation of water and fuel. It does not need to get any hotter than that, IMO there is no benefit beyond that point.
Oil temp typically rises much slower than say cooling system temperature.
Todays oils are light years ahead of what they were 25-30 years ago. I don't think you have much to worry about there if you use something from a reputable company in the recommended viscosity (5w20).
FWIW the 5w20 we use for plain everyday oil changes at my dealer is semi-synthetic and the 0w20 is full synthetic.
I've read that average typical ATF breakdown increases exponentially as it goes above about 200F, and you seem to have plenty of cooling for that fluid.
the bearings........ etc. would have to be MUCH hotter.
The majority of the heat is at the pistons themselves, not bearings.
The EX/VTEC engines have oil squirters that spray the bottom of the pistons to help cool them.
If your oil pan says 180 I think that's a fine temp.
The majority of the heat for the cooling system is in the cylinder head, and to a lesser extent in the water jacket surrounding the cylinder bores.
The engines heat originates in the combustion chambers and areas where the gasoline is burned. Therefore the hottest areas of the engine are immediately surrounding the combustion areas. (ignoring the exhaust system)
Old Nov 16, 2017
  #32
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: Ideal oil temp?
Originally Posted by sdaidoji
have you been in the miatanet?
we were recently discussing that...
If the engine parts are all working correctly, it should be around 180.
but during a heavy traffic, stop-and-go i was while crossing Atlanta, it crept up to 220.
several years ago, engine is still good.
Pressure and temp gauges on my civic. What worries for real is loss of pressure.
Interesting, thank you. I haven't been posting on miatanet, and 180 sounds like a good temp to me for oil. Also, is 220 bad for the engine? Does 220 cause more wear than 180, or is the only concern the oil getting hot enough to break down? Thanks.
Old Nov 16, 2017
  #33
Re: Ideal oil temp?
Good information, thank you. Also, the D17A2 VTEC engine in my 05 Civic LX doesn't have piston oil squirters. So without piston oil squirters, how does oil get to the pistons? I presume that the cooler the oil is (to a point), the more the pistons will be cooled, and therefore the less likely detonation is? Not sure about that. And as for the viscosity, I use 0w20. Is that OK? Thanks.
Old Nov 16, 2017
  #34
Re: Did I tow too much?
TCC unlocks with changes in load.
Correct. Fluid coupling.
The TCC IS a clutch.
Fluid coupling plus mechanical lock. Best of both worlds.
But it is not indestructible. Nothing in the trans is overbuilt, it was only intended to pull around the car it was installed in, not a whole extra car LOL.
Slip-lock: slow regulated engagement and/or partial engagement of the TCC.
I'd say mostly to minimize the drivetrain and driver shock of TCC apply, plus probably more reasons I don't care about.
That's how the engineers designed it.
Just know that it is something they designed it to do.
If you know what you are looking for, you might see it happen on the tach. IDK if it's real obvious on the Civic but I know I can watch it happen on some of the other cars/vans.
If you ever got to drive.... say some older GM cars from the mid 80s to early-mid 90s pops into my mind, their TCC apply was like an ON/OFF switch.....it was sudden and sometimes you definitely KNEW when it engaged. My old 1990 Park Avenue would engage it at exactly 48 MPH if you weren't deep in the gas pedal, and unlock it as vehicle speed dropped below 46.
Thanks. What I don't understand is why wouldn't the TCC stay engaged when under heavy load? Wouldn't the transmission waste less energy, and therefore get more power to the wheels with a direct connection from the engine to the transmission? Thanks again.
Old Nov 16, 2017
  #35
Re: Ideal oil temp?
just drive it.
thinking too much about it unless it goes too hot
Old Nov 16, 2017
  #36
Re: Ideal oil temp?
just drive it.
You're probably right lol.
Old Nov 16, 2017
  #37
Re: Ideal oil temp?
ah, but towing 2 cars worth of weight...
as said before, good luck, hope all goes well, truly...
Old Nov 16, 2017
  #38
Re: Ideal oil temp?
It may run that high at times, especially if you keep a huge load on it.
If you run it hard enough long enough the header can glow too.
Many GMs ran that high as normal operating temp.....The radiator fan kicked on around 223-225F. (Not sure if they still run them that high or not). Running that hot helps increase fuel efficiency, but I'm sure there are trade offs.
LX didn't come with D17A2/VTEC.
I was going by what Sdaidoji said about the piston squirters. ...but I can't find factory service info to confirm that and I can't remember those minor details about the few D17 blocks I've had open in the past.
Forget I said anything about it. Maybe sdaidoji will drop back in and confirm or deny.
Splash.
They all run knock sensor ignition, so it should be a non-issue.
I don't think oil temp has much to do with controlling detonation even if it had conventional ignition. Coolant temp and compression ratios would probably have greater influence on that IMO.
The engines never seemed to have issues with real detonation. I've really never noticed spark rattle (preignition) either.
It's use is approved by Honda for that engine, so "sure".
ALL 0w20 oil is semi-synthetic or better.
Old Nov 16, 2017
  #39
Re: Ideal oil temp?
Splash. They all run knock sensor ignition, so it should be a non-issue.
Good info, thanks. And BTW, I rebuilt a junkyard D17A2 and put it in the car, the car came with a D17A1 that blew up when the cam plug popped out. I can assure you that there were no piston oil squirters in either motor. The blocks, crankshafts, oil pumps, etc. are identical. The only improvements with the D17A2 is 9.9:1 compression vs. 9.5:1, aluminium oil pan vs. steel, exhaust system and cylinder head. That's all that I know of anyway. Thanks for your help.
Old Nov 16, 2017
  #40
Small engine makes little power at low RPM.
Must rev high for more power.
Downshift happens when power is needed.
Converter unlocks with small changes of throttle.
I think TCC is off during shifts (did not check).
A torque converter can multiply applied torque, but that is greatest at stall speed (max RPM difference between input RPM and zero output RPM). There is very little of this advantage when RPM difference is similar, and zero torque advantage when TCC is in lockup.
Old Nov 16, 2017
  #41
I still don't quite understand. I get the "downshift for more power" thing, but if the torque converter is slipping, power is obviously being lost. How could you get a torque increase from losing power? Also, what is stall speed? Thanks.
Old Nov 16, 2017
  #42
http://www.hotrod.com/articles/ccrp-0310-torque-converters/
Google for more
Old Nov 17, 2017
  #43
Oh, I see. That article was very helpful. So the torque converter slipping is basically an inefficient way of gearing down the engine RPM for more torque to the wheels? So does that mean that when the TCC locks, performance/throttle response suffers but efficiency improves? Thanks.
Old Nov 17, 2017
  #44
What effect does open header have on HP?
My 2005 Civic VTEC has a D16Y8 intake manifold, 3 inch custom air intake, DC Sport 4-1 header and 2.25 inch straight pipe exhaust. I recently took the entire exhaust system off to do some work, and the car has no exhaust besides the DC Sport 4-1 header. What effect does an open header have on power? The engine runs fine with or without the exhaust, I don’t think that it runs much different either way. With the stock non-VTEC exhaust, the engine was definately much stronger with no exhaust, but the non VTEC exhaust is stupid small for the modded D17A2, so that is to be expected. So is the engine stronger with or without an exhaust system? Like I said, I really can’t tell much difference in the way the engine runs since I took the exhaust off, but I’m curious about if the power is better or worse. Thanks.
Old Nov 17, 2017
  #45
Stage 1 cam?
How much power would I gain on my 2005 Civic with intake, header, Y8 intake manifold and 2.25 inch straight pipe exhaust if I upgrade to a Crower Stage 1 cam? I have heard mixed results ranging from the difference would be barely noticeable to it is the single best performance mod you can do to a D17 for the money, and the difference is night and day. What do you think?
Old Nov 17, 2017
  #46
mikey1's Avatar
Re: Stage 1 cam?
by the time the extra power gets to the wheels you are probably looking at 8-10hp with all of those mods including the cam
Old Nov 17, 2017
  #47
Re: Stage 1 cam?
So upgrading the camshaft probably won’t improve power noticeably?
Old Nov 17, 2017
  #48
DIY cylinder head porting on exhaust port?
The exhaust port looks incredibly small on the D17 head compared to the exhaust header IMO, so I was thinking of doing a port and polish by hand to try to get better flow. My question is would this be a good or bad idea? I was thinking pull exhaust header, crank engine to TDC on that cylinder to close valves, use a Dremel to enlarge the port a little bit, use a ball hone to smooth it out, blow debris out of port with air compressor and brake cleaner, repeat for other cylinders. What do you think? I think I could gain at least 8-10 HP from doing this. After all, CNC machines weren’t around forever. Performance enthusiasts have been doing this for years, so why not?
Old Nov 17, 2017
  #49
Re: Stage 1 cam?
It was definitely noticeable. Not a lot, but enough to notice over stock
My setup was Crower stage 1, AEM V2 intake, Kamikaze ceramic coated header, Random Technology high flow cat (2.25" piping), A'PEXi WS2 cat-back (60mm/2.36" piping)
Old Nov 17, 2017
  #50
Re: Stage 1 cam?
Cool, thanks. So if someone changed your cam overnight and didn’t tell you, you’d notice?
Old Nov 17, 2017
  #51
Slumpertcivic's Avatar
Re: Stage 1 cam?
If they put the stickers on your windshield....
Old Nov 17, 2017
  #52
Re: Ideal oil temp?
yep, EX have oil squirters on the under pistons. Also, slightly higher compression
that's what have been placed several years ago about the differences in the block
Old Nov 17, 2017
  #53
Re: DIY cylinder head porting on exhaust port?
8-10 HP is being quite optimistic....
Old Nov 17, 2017
  #54
Re: Stage 1 cam?
https://www.civicforums.com/forums/7...ge-1-cams.html
it would be noticed, yes.
estimates are with I/H/E to get about 35HP - the most these engines coukd get.
note: due to Photobucket policy change, a lot of pictures were lost in the link
Old Nov 17, 2017
  #55
Re: What effect does open header have on HP?
the power of the law will quickly catch you from a mile away if you run with only header. Too loud, like a truck. but louder.
you will lose low RPM torque, which is the most important for daily driving. Basic engine theory.
Old Nov 18, 2017
  #56
Re: Stage 1 cam?
Interesting. I don't believe that I'd gain 35 HP over stock though, because that would mean that it'd be making over 160 HP at the crank, which I don't think is very likely from a D17. I could be wrong, I just don't think that a D17A2 is going to make as much power as a stock K20A3 without boost or SERIOUS mods. That would be nice though.
Old Nov 18, 2017
  #57
Re: Ideal oil temp?
Maybe mine didn't have oil squirters because it's a 2001 motor? Maybe oil squirters were added on at a later time? Or maybe Honda frogot to put them in at the factory? It did have higher compression though.
Old Nov 18, 2017
  #58
Good point about noise. I plan to put the exhaust back on this weekend. What happens to top end power with no exhaust though?
Old Nov 18, 2017
  #59
So what would I gain, if anything?
Old Nov 18, 2017
  #60
No matter what, it'll be offset by the severe lack of low end torque. When I first installed my header way back when, it got offset by a half inch. Car sounded like a Harley and couldn't get up a driveway. Car needs backpressure
