DIY cluster swap 2003 - 2004 dx also available for other models
Old Apr 6, 2018
  #211
taweekiat-b1976's Avatar
taweekiat-b1976 is an unknown quantity at this point
Re: DIY cluster swap 2003 - 2004 dx also available for other models
I'm would like to swap my cluster 01 to hybrid cluster if who can do ti please help me please TAWEEKIAT-B@hotmail.com I'm need the hybrid wiring diagrams
Old Jun 16, 2018
  #212
marlouiegene18's Avatar
marlouiegene18 is an unknown quantity at this point
Hello, Im succesful on doing a cluster swap from an 05 to my 02. Although, when I first fired up the cluster, my SRS was off. Few minutes later, it's stuck on. I've tried resetting it to no avail. I've tried checking if there is a SRS code to no avail. Everything works except the SRS light is stuck on. Any ideas? Anything would helpful. Thank you. I double check pin 8-9 in the green plug and they're connected correctly.
Old Jun 16, 2018
  #213
Check if there's an srs light condition? Driver's side seatbelt is a common one in 7thgens
Old Jun 16, 2018
  #214
I've tried pulling the srs code and to no avail. I'm starting to see that the fuel gauge is also stuck on full. My hunch is that the cluster is broken as I picked it up from the salvage yard and the car is totalled. What do you guys think?
Old Jun 18, 2018
  #215
BrotatoChip's Avatar
Super Moderator
I would recheck all your wiring, always possible you mixed a few up.
Old Jun 18, 2018
  #216
I have double checked it a dozen of times. The fuel gauge finally moved, I'm probably not used to how much kilometers I need to run before it moves from full. Though SRS Light is still on. when I picked up the cluster, I cut the wiring harness from the car I took the cluster from so I can physically check it as well. So far, it matches.
Old Jun 18, 2018
  #217
Hello, I just figured it out and it is a wiring issue.
My 02 Honda Civic have 2 pink wires, one from the Blue Plug(SRS wire) and one from the Green Plug(Canada Windshield Washer Sensor). Because they were both the same colour, I mixed them up. I just had to switch around my modified wiring harness on the Green Plug from Pin 1 to Pin 9 vice versa and it worked after resetting the light. No more annoying lights.
I was actually reading up on some of the thread about cluster swap and they have also rimmed on the same SRS issue I rimmed with but didn't see the answer, I just remembered that I might have mixed the pink wires up.
Also Fuel gauge also works well, just not used to it yet.
Old Dec 19, 2019
  #218
Mark Angeles's Avatar
Mark Angeles is an unknown quantity at this point
Hi all!
My GF's 2004 Honda Civic DX from Canada is now having issues with her cluster too. It occasionally dies, every needles goes to 0 and starts working again.
Current cluster:
HR 0279 572
78100-S5A D160
Thinking of replacing her cluster with: 2003 Honda Civic Automatic Speedo Instrument Cluster 78100-S5P-C540 (shown below)
Do I need to rewire or is it plug and play?
Old Dec 19, 2019
  #219
Originally Posted by Mark Angeles
Hi all!
Current cluster:
HR 0279 572
78100-S5A D160
Do you have a photo of the old one_ My guess is that you will need to rewire.
Old Dec 20, 2019
  #220
Colin42's Avatar
Is the orange illumination wire hooked up to the aftermarket deck?
Old Dec 23, 2019
  #221
Attach is the original cluster from her car
Old Dec 23, 2019
  #222
yep, you'll have to re-pin the connectors.
Old Dec 25, 2019
  #223
Thanks everyone. Everything works well. Spliced up ABS and grounded it to turn off the ABS light.
Any idea why the high beam indicator light is on even when the car is turned off? Fixed Blue plug instead of Pin #9 moved to Pin #1
Old Dec 26, 2019
  #224
Super Moderator
Is the red/yellow wire in pin 10 on the blue connector. This is the wire that controls the high beam indicator.
Old Jan 12, 2020
  #225
Michall Thomas's Avatar
Michall Thomas is an unknown quantity at this point
Originally Posted by gearbox
so do I use this diagram for this for swapping a cluster from 2003 ex to 2003 dx?
Old Jan 20, 2021
  #226
FRSam's Avatar
Click Here
No, let it burn to the ground
Old Jan 21, 2021
  #227
Super Moderator
It is possible but some of the gauges won't be used.
https://www.civicforums.com/forums/2...civic-em2.html
rockhound124
Feb 24, 2020 09:05 AM
lilbit_trojan
Aug 3, 2005 07:26 PM
aznrice
Apr 7, 2004 11:56 PM
hi2nr
Apr 7, 2004 11:39 PM
andyman97
Oct 24, 2002 09:30 PM
