DIY cluster swap 2003 - 2004 dx also available for other models
Old Aug 4, 2006
  #151
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
sorry to bring this thread back up but i need a little help here.
I just did this DIY and instead of switching pins i go a 'male and female' connector and just make a "quick switch connection thingy" so i can change back to originial without switching the pins.
Now the problem is, is that everything works, just that my right turn signal doenst work and my gas guage doesnt work (says im outa fuel). Please help meee!!!!! ASAP!
Old Aug 5, 2006
  #152
shifoe's Avatar
shifoe is an unknown quantity at this point
Can you order clusters direct from Honda?
Old Aug 5, 2006
  #153
rice4lyfe's Avatar
i dont know if they allow it, since it is illegal to have a different number of mileage on your odometer and your car. But if they do, it'll probably be a hefty dollar since its the whole cluster.
Your best bet is to go to a junkyard and see if they have one, kinda rare to find but maybe you'll get lucky.
Old Aug 5, 2006
  #154
or ebay. for your problem, it seems like you left out one of the wires, or its loose.
Old Aug 5, 2006
  #155
rice4lyfe's Avatar
hmm..the thing is is that i dont have a yellow/black wire and yellow/green wire.
I found these colours in the other connectors but i duno...
I just dont know where i could find the connection. If anything ill take a picture of it and can u take a look? Other than that, im very happy with the result.
Old Aug 5, 2006
  #156
what exact car do you have? i can look up the diagram colors but i am pretty sure the yellow/green is for the signal light. yea some of them have multiple function too.
Old Aug 5, 2006
  #157
rice4lyfe's Avatar
i have an 01 dx sedan and im switching to an 03-04 (not sure) cluster. They are both manual clusters. Im also pretty sure that the yellow/green is for signal and yellow/black is for the fuel. the connectors that i have dont have the wires in them. But i found that the opposite plug has them, do you think that the wires are thoes ones? I tried it out but i ended up blowing a fuse, so if anything ill try that again. Let me know, thanks!!
oh and btw, i soldered everything so im pretty sure they're on them. Ill take a pic tonight
aiight here are some pics!!
Old Aug 5, 2006
  #158
hmm i know some wires need to switch sides per the diagram...but idk this is confusing. damn you didnt leave all those wires naked like that i hope!!
Old Aug 5, 2006
  #159
rice4lyfe's Avatar
hahha, no i put shrink wrap over them, some of them i had to redo because it was acutall showing too much. Well anyways, i finally got it figured out and everything works now.
RULE TO EVERYONE!!!!: CHECK OVER ALL CONNECTIONS AT LEAST 10 TIMES BEFORE GOING ON FORUMS AND WASTING PEOPLES TIMES!!!
anyways, thank gearbox, you have been great help once again!!
Old Aug 5, 2006
  #160
nice! glad it got fixed. usually ends up being a wire issue.
Old Aug 10, 2006
  #161
Jermo's Avatar
Jermo is an unknown quantity at this point
i have an 02 civic lx and a 94 civic ex. i wanna put a new cluster in the 94. whats the newest gen that will work in it
Old Aug 23, 2006
  #162
Em2onCPRs's Avatar
DU MA Con Cac
Em2onCPRs is an unknown quantity at this point
does anyone have a diagram for 01 ex auto w/side bags to 03 ex manual w/o side bags??
Old Aug 24, 2006
  #163
its all the same youre just going from old to new. the only thing you might have is an extra wire for the side airbag but maybe not.
Old Oct 25, 2006
  #164
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
I bought an 03 Cluster and i have a 05 VP, after repinning both connectors, what color wires are never hooked up? I think i read one was white/red. Im trying to make this as idiot proof as possible. In regards to the ABS light, its the Blue/Red wire according to the list hi2nr posted earlier, if its hooked up in my car will it remained lit as i dont have ABS? Can i get around this by not plugging it in or grounding it? Thanks guys.
Old Oct 25, 2006
  #165
rice4lyfe's Avatar
you will not have a light connected to it, since you do not have abs in the first place.. well that was in my case... im pretty sure its the same..
Old Nov 2, 2006
  #166
Buds302's Avatar
Buds302 will become famous soon enough
sup guys... i recently picked up an 02 EX coupe with 70000 miles on it. its a 5 speed and i dont believe it has side air bags. there was an 05 EX coupe special edition on the show room but it was out of my price range...i really likethe cluster in that. and from what i read.the 03-05 clusters are all the same? well the LX and the EX ones are right? another question is..the wiring diagrams you have listed are what the plugs in the 01-02 are supposed to look like after you swap the wires? or is that what they look like stock?
Old Nov 2, 2006
  #167
rice4lyfe's Avatar
the location of the wires are what you change the plugs into. If you're looking for clusters, ebay or a junk yard should have them. Manual clusters are harder to come buy but they're out there, just gotta look hard. good luck!!
Old Nov 6, 2006
  #168
hdave's Avatar
hdave is an unknown quantity at this point
help!!!
I did this and some of my wires colours are different than the ones in the DIY
I have an 05 Special Edition (simlar to vp i think)
help!!!!
Old Nov 6, 2006
  #169
Buds302's Avatar
um..the SE is the top of the line other than the SI here...thats the cluster you should have already that i want!lol
Old Nov 6, 2006
  #170
ya special edition already has the new one
Old Nov 6, 2006
  #171
hdave's Avatar
in canada the special edition is pretty much a base civic
it has: auto, a/c, power windows, keyless entry
and thats it
i thinjk its like the vp
Old Nov 7, 2006
  #172
wow that sucks over here in usa its better than ex. comes with better rims, radio, few extra things too inside.
Old Nov 7, 2006
  #173
hdave's Avatar
can anyone think of any suggestions to my problem?
Old Nov 7, 2006
  #174
Buds302's Avatar
wait..the SI in canada is the EX in this country. and the SE also is the EX in this country. cause i have all that you mentioned and mine is not an SE. its an EX. this means he has the temp guage all the way next to the tach on the left and the fuel guage on the right next to the speedo. correct me if im wrong.
Old Jan 18, 2007
  #175
i5r's Avatar
i5r
i5r is an unknown quantity at this point
my frd got 01 dx, and we want to put 04 1.7el, which civic model would the el match up to ? ex?
Old Jan 19, 2007
  #176
rice4lyfe's Avatar
^ yep, its a higher model of the civic, but same platform
Old Jan 23, 2007
  #177
i5r's Avatar
i5r
therefore needing to rewire the 04 EX(EL) to an 01 civic dx ?
Old May 30, 2007
  #178
c0untace's Avatar
c0untace is an unknown quantity at this point
Re: DIY cluster swap 2003 - 2004 dx also available for other models
Greetings.... I have a 2001 civic LX and a friend gave me an 03 civic EX cluster......03-04 cluster to a 01-02 civic....is that possible???
Thanks....
Old May 30, 2007
  #179
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
yeah
Old Jul 17, 2009
  #180
hondafromeurope's Avatar
hondafromeurope is an unknown quantity at this point
Can you also mail me your excel sheet, thx
marcdevette@kabelfoon.nl
