Update for EMANAGE: WORKING SETUP FOR EXs!!!
Old Feb 5, 2008
  #151
GIOSAFAT's Avatar
GIOSAFAT is an unknown quantity at this point
Re: Update for EMANAGE: WORKING SETUP FOR EXs!!!
so after 11 pages....what is ultimate wiring diagram?
Old Feb 5, 2008
  #152
briand17a2's Avatar
briand17a2 has a spectacular aura aboutbriand17a2 has a spectacular aura about
Thread is old. Im working on the 02-05 EX + emanage vtec issue on my own right now. This will probably require a piggyback-piggyback to pull vtec signal, condition it, output to emanage, input from emanage and output to vtec engage solenoid.
if they could just write the manual in english. As far as just getting it to work, ive hashed this issue at least twice in the last 6 months, not to mention the many hashings by many capable people before then. Search the forums a bit. Good luck. Ill keep you posted with further developments ECU-wise if I can make any progress (without torching my own ECU)
Old Feb 6, 2008
  #153
GIOSAFAT's Avatar
Originally Posted by MadWheel
Here's what it's set to...
Ehm, sorry, help me? where is this form? I don't find it in e-manage software. I have last version!
Old Feb 6, 2008
  #154
ronaldo9's Avatar
Go to Settings-Main Unit Setting Information on the support tool
Old Feb 6, 2008
  #155
GIOSAFAT's Avatar
i don't find it.
i have problem with
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
How do it?
Old Mar 8, 2008
  #156
Lukezen27's Avatar
Lukezen27 is an unknown quantity at this point
fixed fixed
Old Mar 8, 2008
  #157
briand17a2's Avatar
Great info Sir, thanks for sharing your success.
I was thinking, if the eManage needs to see a +5vdc or +12vdc signal on its "VTEC" wire, and the factory ECU uses a -5/-12vdc (whatever voltage it is) to sense VTEC solenoid energization, could you use a relay or a transistor + bias resistor to invert the input to one or the other? That way, both inputs (the inp on the eManage and the inp on the ECU) would be getting their respective "high" signal, but the two signals would be inverted, as required, and you wouldnt have the nagging code.
Just a thought. If im way off base, my bad. Thanks again for the helpful post. Good luck. -Brian
Old Mar 9, 2008
  #158
Lukezen27's Avatar
Delete Delete
Old Jul 5, 2009
  #159
djarmyssg's Avatar
djarmyssg is an unknown quantity at this point
Any new update on getting the emanage to work... ive read like ever single thread about this and still havent found a reliable answer!!! HELP!!!!!!!
Old Jul 23, 2009
  #160
shawnforeal's Avatar
shawnforeal is an unknown quantity at this point
would the Emanage be of use to a car with stock engine, cold air intake and cat back exhaust? no other mods. its a 2002 EX?
Old Jul 27, 2009
  #161
ronaldo9's Avatar
No its a waste of your money. You won't gain that much performance from it for the price for it to be justified.
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
Thees1
Apr 14, 2015 08:23 AM
supercivic01
South
Nov 30, 2001 11:27 AM
