Update for EMANAGE: WORKING SETUP FOR EXs!!!
Old Nov 1, 2004
  #91
bakablo's Avatar
bakablo is an unknown quantity at this point
you could have said something.. Id love to meet you
what area you goto?
Old Nov 2, 2004
  #92
dezod's Avatar
7thgen Power Maker
what area you goto?
Usually dowtown T.O. like Younge St area by the Eaton Centre. Good record shops there. Play De Record y0! LOL
Old Nov 2, 2004
  #93
bakablo's Avatar
im guessing sam the record man u passed by....
yah its cool.. lotsa done up cars on dufferin street tho.. u should have gone by there
Old Nov 3, 2004
  #94
dezod's Avatar
7thgen Power Maker
Actually Play De Record is where I go............
Old Nov 12, 2004
  #95
bakablo's Avatar
any1 have a gsc file for 7thgens with boost or anything.... i need to
Old Nov 12, 2004
  #96
bakablo's Avatar
just before i goto the dyno... any1??? my dyno appointment is monday
Old Nov 12, 2004
  #97
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I would as well like to see such a magical file....
Old Nov 16, 2004
  #98
Crackhead79's Avatar
Originally Posted by opto_isolator
To use the vtec setting in the emanage - try this:
if you are using the emanage to control the engagement point you will need to connect a resistor in parallel with the emanage's VTEC input. Without the resistor the ECU will think that the VTEC solenoid is faulty/not connected and will throw a CEL. Use a 820 ohm 1W resistor.
...see I think this was something that was supposed to be done in the first place, didn't everyone recieve a resistor with their E-manage? I did but is it for something else? Sorry for nagging questions, thanks for the help.
Old Nov 16, 2004
  #99
opto_isolator's Avatar
No, the resistor was for something else (Nissan or Mazada engine setup).
As far as I'm aware, no one took the time to do this....don't understand why.
Anyhow, give it a shot and see what happens.
Old Nov 16, 2004
  #100
HyaBoosta's Avatar
how do you go about installing the ignition and injector harness?
Old Nov 27, 2004
  #101
bakablo's Avatar
ok guys.. i got my car installed with the e-manage will all harnesses and tuned.. and vtec is working on the 4-8-e settings... I have no idea how they installed all of this but if you want I can take a pic of the connections and send it over...
Old Nov 27, 2004
  #102
Tuned, cool...What kind of HP numbers did you get?
Are you willing to show us screenshots of the tuned maps, or maybe the gsc files themselves, hint hint.
Did the tuners tell you anything special about how easy or hard it was tuning with the e-manage?
Old Nov 27, 2004
  #103
One thing I want to know is what the support tool parameter setting says with the 4-8-e setting. That setting is supposed to be for RSXs, but when I set mine to that the support tool doesn't say anything regarding what engine type it is for - its just blank.
Old Nov 27, 2004
  #104
bakablo's Avatar
ill give u guys wghat i got.. its only 1 hr of tuning.,.. after 4-5th gear.. on 4500 rpm i cut out on fuel.. no i cant gun it hard on 4th and 5th.. but im a city driver so it doesnt affect me... it needs to be further tuned.. if you guys can tell me how to save my settings.. ill put the gsc file here available for u guys.. since no one else wants to help us.. i guess you can work from there..
i pushed out 150 whp and 170 tq
on 1st i cant keep the car straight.. i skid all over the place
Old Nov 27, 2004
  #105
HyaBoosta's Avatar
hey if I hooked up the power and ground of the emange to the ecu and then hook it up to the support tool it should communicate right? and did anyone else have to get a serial to usb adaptor to hook it up to their laptop?
Old Nov 28, 2004
  #106
bakablo's Avatar
i got a usb/usb connection
its a clone cable
Old Nov 28, 2004
  #107
HyaBoosta's Avatar
so i just need any random usb cable?
Old Nov 28, 2004
  #108
HyaBoosta's Avatar
if i have the 12v wire connected and the ground wires installed should it connect and interact with the support tool? cause im not sure if it's the usb to serial connection messing me up or if it's the wiring.
Old Nov 28, 2004
  #109
bakablo's Avatar
no.. u need a made support tool.. any usb/usb cable wont work and might burn ur e-manage...
I bought a 6V battery.... connected my e-manage to my pc and updated it... and it interacted fine..
Old Nov 28, 2004
  #110
HyaBoosta's Avatar
i have the cable that came with the support tool then i connceted the serial conncetion to the usb on my lap top. I know you can burn it out but i mean the power wire that connects from the main harness of the emenage and the ground. if i hooked up those two and turn on the carshouldn't it interact?
Old Nov 28, 2004
  #111
bakablo's Avatar
yah.. its possible
Old Nov 28, 2004
  #112
HyaBoosta's Avatar
how many wires did your main harness come with.
Old Nov 28, 2004
  #113
bakablo's Avatar
i have all the harnesses... so i dunno
:P
Old Nov 30, 2004
  #114
dezod's Avatar
7thgen Power Maker
The main harness encompasses, if I remember correctly the injector harness, which needed to be pinned in to the main harness. The ignition harness is completely seperate and requires it own pinning. This question has already been answered for you.....
Old Dec 13, 2004
  #115
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Lately I have been running a S-AFC2 but last week I got an Emanage and an ignition harness. I was curious to how much people retard their ignition under boost?
Old Dec 31, 2004
  #116
HyaBoosta's Avatar
hey we have this write up here for how to install the emanage but how do you install the injector harness?
Old Dec 31, 2004
  #117
This is the hardest thing about the 7th gen, since the computer is continually adjusting the timing. I've tried to log things with the elmscan...but nothings perfect.
Titan set it around -6 degrees at boost when they tuned my car.
Old Dec 31, 2004
  #118
TheSmuggler's Avatar
So you took it to titan, because im looking to take my car to some place if i get a kit and have them install and tune
Old Dec 31, 2004
  #119
Yeah, I did - but they aren't cheap....just to let you know!
Old Dec 31, 2004
  #120
If you don't mind me askin, how much do they charge and how much did you end up payin'.. wonder how much it would cost to have the kit installed and tuned... lol
