SFpower Turbo Kit
Old Apr 15, 2003
  #31
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
I need an electronic boost controller, because my wastegate is set to 5 psi, and last night it was very cold, and it made 10 psi.
It took off like a damn rocket and spun the tires into 3rd gear. Today it is back to 5 psi since it is warm again.
I think and electronic boost controller would prevent these unexpected horsepower gains, and control the boost a bit better. (but the engine and fuel kit held the 10 psi)
Old Apr 15, 2003
  #32
iamboo's Avatar
Retired - SoCal FI Mod
you've been running your setup with a manual boost controller ??
Old Apr 15, 2003
  #33
Bartkat's Avatar
Originally posted by Catalyst
The turbo shows it's stuff at around 3000 rpm. It comes on hard at 3500. Look at the torque curve, it is pretty damn good for a honda. My CRX's curve didnt even look like that, and it made 50 more whp.
The curve I'm looking at has the horizonal axis as MPH. I see the torque and HP curves cross at aroung 75 to 77 MPH. No way to tell the RPM without going back to see what gear you used.
BTW: I'm trying to help you out here, but if you don't want, then I can always start nit picking . You should see that so far I've been giving you the benefit of the doubt, even though there appears you need lots more development before you market this as a kit.
Old Apr 15, 2003
  #34
greatcasa's Avatar
greatcasa is an unknown quantity at this point
I don't believe he's marketing the kit. Simply the guy who had a custom made kit that has led to it being mass produced and the spreading the word.
Old Apr 15, 2003
  #35
cdmx's Avatar
OK thank god theres another thread, i was going to start one up for the sfpower turbo talk...But anyway I AM REALLY INTERESTED but i have an EX...Tell him he better make a kit for the EX because i will be getting a second job to buy this kit....Im looking to get this kit at the end of summer.....
Also i have an important question mabye someone can answer....When putting a turbo on our motor what interals should be replaced first to put either higher boost or just to have a longer lasting motor....Ive heard the block can take 12psi
Old Apr 15, 2003
  #36
reytito's Avatar
maybe this can give you an idea...
i asked the same question
Old Apr 15, 2003
  #37
cdmx's Avatar
Perfect, i flame myself for not searching...BAD CDMX
Thanks man
Old Apr 15, 2003
  #38
Catalyst's Avatar
i am sorry barkat, i do appreciate your help. i was wrong when i said i dyno'd it in 4th gear. I found out that it was 3rd gear. So if you look at the graph, the power is related to speed in 3rd gear. And this kit is being mass produced, and it will be set to 7 psi. There will be an EX kit, as soon as we get an EX in there to make the downpipe. I am going to dyno my car again at 9 psi when i get a clutch. I know the internals can hold it because my car boosted 10 psi the other night when it was freakin' cold outside (i set my wastegate to 6 psi when it was hot).
Old Apr 15, 2003
  #39
Bartkat's Avatar
No problem. It seems you were getting a few flamelettes at the time.
Old Apr 16, 2003
  #40
SFpower's Avatar
Former Sponsor
SFpower is an unknown quantity at this point
yes the kit will be in prodution on monday i will be posting pics dynos and some 1/4 mile times at a better track the times posted where done at L.A.C.R. and if you follow import drag racing youll know it is one of the slowest tracks in the country.any way the kit will be on group buy need at least 10 people in order to give a good deal
Old Apr 16, 2003
  #41
score00's Avatar
score00 is an unknown quantity at this point
you said you were needing/going to put an electronic boost controller on - will you be offering this controller as an option for the kit?
Old Apr 16, 2003
  #42
reytito's Avatar
also how can you be so sure the internals can handle up to 7 - 10 lbs of boost. that night you ran at 10 was relatively a short amount of time. what about long term at 7 - 10 lbs?
Old Apr 16, 2003
  #43
iamboo's Avatar
i wouldn't run my car at 10 psi all the time.. just because i know my parts aren't bulletproof... remember 4-5 psi daily driver setting and 10 for a race setting...
Old Apr 16, 2003
  #44
1982's Avatar
1982 is an unknown quantity at this point
Originally posted by FlyRiceRacer02
Don't worry about those dummies. They wouldn't know how to drag if someone drove their car for them in the race.
i cant drive?
Old Apr 16, 2003
  #45
Bartkat's Avatar
Originally posted by 1982
[B]i agree, those look like some sorry #s, but gotta factor in the elevation and wind against you. my thoughts: driving skills need definate work.B]
Old Apr 16, 2003
  #46
cdmx's Avatar
Ok, im pretty sure im going to try and save up for this kit, end of the summer...How much is the normal price
Old Apr 16, 2003
  #47
azure's Avatar
I believe the last thread said $3500, if I'm not mistaken. But $2900 if SFpower has 10 or more people in on this GB.
Old Apr 16, 2003
  #48
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i want to be in on this gb cause the price is just about right for a complete kit, but i just saw another thread that derty posted about turbodiscounters coming out with a kit soon.price is about the same too so im stuck on deciding which kit would produce better gains on a set psi.
Old Apr 16, 2003
  #49
azure's Avatar
I feel the same way CIVIC808. DIZZLE made a thread about turbodiscounters as well. Although I'm leaning more on SFpowers turbo kit because I know it fits the LX.
Old Apr 17, 2003
  #50
cdmx's Avatar
yeay turbo kits, turbo kits!!!
Old Apr 17, 2003
  #51
iamboo's Avatar
okay... i called sf today... he said he'll be posting the group buy on monday...
basically the group buy will only last for a month from monday.. unless we all convince him otherwise... ummmm.... mass production of the kits will start monday... he won't sell the manifold or the fuel system seperate so if you're thinking that then you're pretty much outta luck...
so do whatever you can to get as much cash together as you possibly can and lets get this group buy going!!!
Old Apr 17, 2003
  #52
azure's Avatar
Coo! Thanks for lettin us know iamboo!
Old Apr 17, 2003
  #53
CIVIC808's Avatar
great...i hope he can make it for the ex.
Old Apr 17, 2003
  #54
CIVIC808's Avatar
oh do we need to cut the front bumper for the intercooler?looks kinda big without modifications.
Old Apr 17, 2003
  #55
azure's Avatar
CIVIC808 - Yah, but just the grill part. Catalyst said that the lower plastic grill piece was cut a little in order for the intercooler to fit.
Old Apr 17, 2003
  #56
Catalyst's Avatar
I will take a picture for you guys so you can see how much i needed to cut.
As of right now, i am running 8 psi. my clutch is holding up well (i might add). I havent been slamming gears, just shifting mildly. The car seems to be much much happier with the added 2 psi.
I havent told you guys this before, but on our first pull on the dyno, we made 150 whp @ 5 psi, and then (the one you guys saw) 165 whp @6.5 psi. So i would imagine that i gained quite a bit power from this 2 psi. I am hoping to be sponsored by a local parts store (that carries ACT clutches) and hopefully i will get a clutch. So when i do, i will post some new dyno numbers.
And as for that turbodiscounters crap, i mean turbo kit.... Would you rather have a "Custom Turbo Kit" with an intercooler, or would you want a "Discounted, Thrift Store Turbo Kit" without an intercooler (unless you pay more to upgrade)???
I would rather have the custom kit.
Old Apr 17, 2003
  #57
cdmx's Avatar
cool, can the lower grill be shaved enough for it to still be there? If i put the kit in i want to keep that and put some metal mesh painted black...sleeper sleeper!! damn i hope i can save enough for this kit...SFpower is awesome!! btw im not in the group buy but ill still buy the kit hopefully end of summer
Old Apr 17, 2003
  #58
Catalyst's Avatar
Im sorry, but you must remove all of the grill. You guys will see it when i post. You have to remove most of the "Black Part" of the bumper. There is about 1 inch left of the "Black Part". CDMX, i want to do the same thing. there is still enough left to where you can put the black mesh in. I was going to do that this weekend, but my parents are taking me out for the entire weekend to celebrate my B-Day (tomorrow). So i will do that later.
Old Apr 17, 2003
  #59
cdmx's Avatar
cool, thanks post pics when your done!
Old Apr 17, 2003
  #60
CivicLX620's Avatar
CivicLX620 is an unknown quantity at this point
I wouldnt even want the bottom grill on there anyway. I would want people to get a better view of the intercooler.
Joel
