The 7thGen Swap FAQ.
Old Mar 13, 2006
  #241
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
I use a 2003 Accord ECU ... so this one doesn't have a drive by wire throtle. I already pin the wire in the C101 plug and the o2 sensor wiring is the same way as I did last year with my k20a2 ...
For the reflash I have the Accord key and transponder, so I didn't need to reflash it ...
I'm not a newbie with the wiring and I know what I should do... I only ask about the 31 E pin. This seen to be the only trouble I see after everything else was wire. If I can't have the OEM MIL.... We just buy a cheap code scanner for 150$....less expensive than a KPro.
Old Mar 14, 2006
  #242
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
so it seems you know what you are doing.. so if this is the case then why are you asking how to do the swap???
Old Mar 14, 2006
  #243
Dark2k1's Avatar
I don't asking how to do the swap... I asked if someone ever do it with the stock k24 ECU
:P
Old Mar 14, 2006
  #244
lol.. well keep us updated when your done
Old Mar 19, 2006
  #245
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
this is crazy, Dark2k1, i swear to god you have been working and talking about this for like 2 years now, lol.
Old Jun 15, 2006
  #246
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
that part list on hasport, it says for k20a2/3. are those the same parts for k24a2/k20head or are there additional/less parts required?
Old Jun 15, 2006
  #247
wantaturbo's Avatar
wantaturbo is an unknown quantity at this point
as far as a stock block all the swap parts are the same except the passenger side mount. you need to modify it or call them to see if they have come out with a k24 mount kit cause last time i talked to them it was in the works. also you will need to use a k20 thermostat housing and hard line cause the k24 housing is mounted at a different angle. oh and depending on what header you will be running, your front sway bar probably wont fit. good luck
Old Jun 21, 2006
  #248
blk03coupe's Avatar
blk03coupe is an unknown quantity at this point
I wonder if all the work that is done on the swap it might be more effective to just buy a used RSX-S.
Is it truly that much better or more fun to have all of the RSX parts on a Civic? I am attracted to the idea for sure-but it just seems like a helluva long way to go to get what may end up costing as much as a used RSX-S.
I'm including the cost of the Civic-mine was 15,200 new. Add $3000 or so for the motor, another $1,000 for mounts, radiator, re-flash of ECU, plus at least $500.00 for labor. Couldn't you get an RSX S for $19,500?
Is it the mystique of having a "sleeper"? Let me know.
Dwight
Old Jun 21, 2006
  #249
You VTEC...I-VTEC
well put think about this, if you had an rsx would you do the same things to it to make it bigger and better? I do not know if engine swaps are the thing to do for an rsx but... you would just end up spendin more money on that. IMO of course correct me if i am wrong
Old Jun 22, 2006
  #250
blk03coupe's Avatar
Bigger and Better
I don't know. Perhaps I would try to make the RSX-S better. Who knows?
I don't have the money to do either so I'm probably just jealous of people who spend that much on it in the first place.
Logically thought it seems like you'd just buy the faster car first rather than the economy car-like my 2003 Civic EX. Whopping 1.7 liters of displacement.
It seems like the better platform would be the RSX-S but then again we are in the 7thgencivic forum
I'd love to own just a decently powered autocross car with some great suspension, wheels, and tires. I'm itching to get some track time-going to the mid ohio event this weekend to check out the TSXs and the open tuner class races. It should be a blast.
Peace to all,
Dwight
Old Jul 5, 2006
  #251
ESK1k20A2's Avatar
ESK1k20A2 will become famous soon enough
02 sensor secondary
Originally Posted by Hawk
If you order the harness from hasport it is plug and play. The only thing you have to wire up is the secondary o2. I can send you the wiring explination that Brian sent me if you need it.
would u pls send it to me?
Old Jul 5, 2006
  #252
ESK1k20A2's Avatar
02 sensor secondary
Old Aug 14, 2006
  #253
skunk2civic04's Avatar
skunk2civic04 is an unknown quantity at this point
Before anyone starts flaming, I read through all 17 pages and didn't see this answered. I have a 2004 civic EX, but it's automatic(I know, I know). I've come to the decision I need a K20A2 and was wondering how difficult would it be to change my civic over to manual transmission? What parts would I need? Would it be best to use the clutch and pedals from the donor RSX, Si, or the stock manual EM2? Thanks.
Old Aug 14, 2006
  #254
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
**** man its alot of work.. I did it. You need a clutch pedal and a new brake pedal along with clutch master cylinder and all the other **** for the swap as well.
Old Aug 15, 2006
  #255
civicvteceg's Avatar
civicvteceg is an unknown quantity at this point
i dont know what else to do with my d17
i have a civic ex d17 vtec... is there anyway i can get this puppy to go faster... any recommendations...
hey what can i do with my civic ex d17
Last edited by civicvteceg; Aug 15, 2006 at 05:12 AM. Reason: Automerged Doublepost
Old Aug 15, 2006
  #256
mclean987's Avatar
mclean987 is an unknown quantity at this point
depends how much you wanna spend ? turbo or all motor? you can go usual boltons but they got stage 2 cam now makes a nice difference, most people are gonna say swap in rsx or type s motor
Old Oct 19, 2006
  #257
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
k20s are expensive. can a H22 fit?
Old Oct 30, 2006
  #258
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ with enough money you can make any motor fit... but you just said k20s are expensive so in your case... no it will not fit.
" This thread is about K Series Swaps! Not about how to make your D17 faster or what other kinds of motors can fit!"
Old Oct 30, 2006
  #259
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
let him try .. lol .. id love to see a h22 powered es1.. plus his car wouldnt pass any kind of emissions.. be illegal in most states...
the only motor that goes in 01 and up civic is the k series..
Old Nov 6, 2006
  #260
EXsmellsbetter's Avatar
Mr. Treehorn treats objects like women, man!
EXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura about
Does anyone know if a Jackson Racing supercharger will fit on the K20 still after it's been swapped into a Civic? This question has been plaguing me and I can't find an answer, no matter how much I search.
Old Nov 7, 2006
  #261
Nameless's Avatar
TURTLEonK
Yes, it has been done... I believe they used a JRSC for an EP3. Look for TransformedBG's thread.
Old Nov 8, 2006
  #262
Ahh, thanks for the input. I just talked to one of the SoCKS guys and he said it will bolt on as well, so that's exciting!
Old Jul 1, 2007
  #263
LT2004ever's Avatar
I wil fix vBPlaza today
Re: The 7thGen Swap FAQ.
hey man this link no worky
http://www.hasport.com/News/Articles/ESK1parts.htm
Old Jul 1, 2007
  #264
DsevenEm2's Avatar
This is Myspace
its alivvvveeee!!!
Old Jul 1, 2007
  #265
LT2004ever's Avatar
yup its been revived... hehe
Old Aug 24, 2007
  #266
k20em2504's Avatar
k20em2504 is on a distinguished road
I have an A3 swap in my EM2. Will a EP3 catback exhaust bolt up to the stock SI cat in my EM2?
Old Aug 29, 2007
  #267
Niterider2gen's Avatar
Niterider2gen is an unknown quantity at this point
HEEEELP this is my first time on here. I have an 01 with a bolt on from turbo specialties. On the dyno it put out 146 whp and 136 torque its fasssssstttttttttt, but I'm hamving issues upon take off in 1st and second. Any advice???
Old Aug 30, 2007
  #268
DsevenEm2's Avatar
This is Myspace
sooo why the hell would u post that here? this isnt for ur questions.. its a FREQUENTLY ASKED QUESTION THREAD about SWAPS...
make ur own thread in the turbo/swap thread board.. about ur problems..and also be specific..from the sounds of it, ur having a hard time driving? i guess. be specific and tell us what u mean and dont post it in here..
Old Mar 20, 2008
  #269
Hataish's Avatar
Hataish is an unknown quantity at this point
Hi, This post is very informative, however there are some queries to ask about some specific topic. If someone can help me then please send me a private message. Thanks,
Old Apr 5, 2008
  #270
FROSTY90's Avatar
FROSTY90 is an unknown quantity at this point
make sure theres light or no damage to the front of the car, you don't want to have to replace stuff on the motor, or find out later theres a leak or something.
I avoid front end damage for sure
