Kennykid2002's Build Thread
Old Dec 1, 2012
  #181
mac25's Avatar
Dr Krieger of Modification
Re: Kennykid2002's Build Thread
sick, can't wait to see your wheels done.
Old Dec 1, 2012
  #182
Kennykid2002's Avatar
Kenny the Ricer
Originally Posted by sdaidoji
oh, ****, touche! I drive two mx-5, so...
Well, I guess you'll have to keep two hands on a stick.
Wait, wat.
Wheels are done o.o
Old Dec 4, 2012
  #183
Kenny the Ricer
Got the damaged rim replaced.
Next project will probably involve the trunk floorboard.
Old Dec 5, 2012
  #184
PearlVic's Avatar
PearlVic is an unknown quantity at this point
What's goin down there? Lol
Old Dec 5, 2012
  #185
Kenny the Ricer
Fitting the full size tire there, probably.
I was hoping also, to bring the amp below the floorboard, and cover it with plexiglass. Then stash some LEDs in there.
Making more room.
I was considering if I didn't use the rim as a full sized spare, that I'll take out the current spare tire, build a custom sub enclosure in that space, put a grill on top, and I'd have my full trunk to use again.
Old Dec 12, 2012
  #186
Kenny the Ricer
With the winter storms pounding Cali recently, my RainX wipers were ready to retire.
Got some decent wipers from Costco for $8 a pop.
Old Dec 13, 2012
  #187
Kenny the Ricer
Also finished Seafoam tonight.
Old Dec 13, 2012
  #188
sl33pyriceboi's Avatar
Did you see a butT load of smoke?
Old Dec 13, 2012
  #189
Kenny the Ricer
I saw your butt
Wait
Wut.
Lol yeah, it was pretty intense for like 10 mins
Old Dec 16, 2012
  #190
mac25's Avatar
ha ha Domo =D
Old Dec 16, 2012
  #191
yer jealous of sl33py stiff butt?
Old Dec 16, 2012
  #192
Kenny the Ricer
Mini DIY: RSX Sway Swap
Got my stock RSX sway 19mm today.
I was planning on going 21mm, but the 19mm was cheap enough for me to hop on it.
The ends were slightly rusted where the paint had come off.
When I got it
Decided to sand it down and paint it to prevent further rusting.
Used what I had in the garage, primer, primer sealer, and a little bit of white enamel.
No paint booth?
Ricer innovation!
Didn't have enough white to do multiple coats, so I just went with one thick coat.
Didn't get 100% full coverage though.
Here it is finished.
So time to take out the toothpick of a sway.
Size 5 hex key, with adjustable wrench will do; sockets will just turn the nut indefinitely. Do on both sides and take off the two mounts with 4 12mm bolts.
Compare the toothpick to the monster
Reassemble opposite of assembly.
Tada!
It feels a lot better in the corners now, body roll is significantly reduced.
There's still some, but it's manageable.
Old Dec 16, 2012
  #193
nao change your struts so u can has less body rollllllll
Old Dec 16, 2012
  #194
PearlVic's Avatar
hahaha your painting process is funny, looks good, uhm question, you probably didnt notice this but did the 19mm sit closer to your exhaust than the 13mm did? thats why i'm worried about getting the 21, because my stock one is fairly close to my 3" exhaust pipe and if i hit a bump hard enough my stock sway bar actually rubs my exhaust pipe a little bit lol
Old Dec 16, 2012
  #195
Kenny the Ricer
The paint process is the same whether you're in a booth or out on a balcony.
You hang up the piece to be sprayed and spray it down.
The sway sits nowhere near my exhaust.
But that may be due to the exhaust being angled out.
Plus, I don't have 3" piping lol
Old Dec 16, 2012
  #196
PearlVic's Avatar
lol cuz i aint trying to get the 21mm and be destroying my exhaust
Old Dec 16, 2012
  #197
CGaud's Avatar
CGaud is an unknown quantity at this point
This was one of my favorite mods because it's cheap and you can notice a big difference in the corners.
You may want to look into upgrading your endlinks with something a little beefier like MOOG (w/ grease fittings). When I upgraded to the 19mm I didn't change my endlinks and when installing my Neuspeed sway & brace I found out that my stock links had snapped in half. Perhaps yours looked good and will hold up but in my case they didn't.
Old Dec 16, 2012
  #198
Kenny the Ricer
I did consider upgrading the end links and bushings before going down there.
Got down there, end links were like new condition, not even seized (albeit, some rust on the end of screw).
Washed the bushings, and they were like brand new as well.
Old Dec 16, 2012
  #199
PearlVic's Avatar
Kenny kenny kenny . . .
Old Dec 17, 2012
  #200
krudmuphin's Avatar
I'm ghetto with my 21mm.
I have a foam pad taped onto the bar so it doesn't hit the exhaust, lol
And I'll be rocking my stock endlinks until they snap and I veer off the road and die.
In which case, I'll be happy, because I won't have to work at Walmart anymore.
Old Dec 17, 2012
  #201
Kenny the Ricer
Angled ricer exhaust ftmfw lol
Plenty of clearence.
Old Dec 17, 2012
  #202
PearlVic's Avatar
lol Dylan thats actually a hella good idea...
Kenny... thats the same exact text message you sent to me... ghetto ***. lmao
Old Dec 17, 2012
  #203
I clamped a piece of leather in my progress sway bar, but couldn't take the clank anymore so installed the smallest muffler i could find, so it would hang higher...
Old Dec 18, 2012
  #204
rjones7755's Avatar
I want the 21mm but i dont want it to tear out of my frame lol
Old Dec 18, 2012
  #205
21 RSX should be OK accordingly to other members.
i personally use the progress which came with the reinforcements, but much more expensive and thicker (22mm)
Old Dec 18, 2012
  #206
Kenny the Ricer
Hard to find, but if you plan to buy it new, I think it's like $75 online.
If you can, at least upgrade to the 19, makes a world of difference.
New tires/rims, springs, sway, seafoam; I feel like it's a whole new car.
If I wasn't getting so much road noise, I'd swear I was in an old luxury car.
Old Dec 18, 2012
  #207
rjones7755's Avatar
Yeah ive got the 19 wit es bushings...i want to get tokico blues next and then definitely new tires even thought they're only a year old lol. Did the seafoam help that much?
Old Dec 18, 2012
  #208
krudmuphin's Avatar
I'm pretty sure the 21 isn't going to tear the subframe out of an EM2.
That extra 2mm doesn't seem like much of a problem. The endlinks are bound to get destroyed though...eventually.
Old Dec 18, 2012
  #209
Kenny the Ricer
Yeah, definitely.
Quite down the engine, and shifts a bit smoother.
Exhaust got slightly louder
Old Jan 13, 2013
  #210
Kenny the Ricer
Painted my rear drums.
Didn't turn out as black as I thought it'd be.
But I sort of like this gunmetal gray type color.
Didn't get to do front calipers, will probably get to do them tomorrow.
Before:
After:
Before:
After:
