ECU Fried 7th Gen cars have a Chronic issue - alternator bolts get loose and the loss of grounding will eventually fry the ECU
No RMP or Temp gauge, sputtering engine, stalling
Old Feb 16, 2021
CivicNewbie10's Avatar
CivicNewbie10 is an unknown quantity at this point
Unhappy No RMP or Temp gauge, sputtering engine, stalling
Hey guys, my civic was running great no signs of anything going bad, then on my way to work i noticed the RMP and the temp gauge were not functioning. The car started to sputter as if not enough fuel was getting to the engine and stalled out. I was able to start her up again and get it back to my house by staying in second gear and keeping the RMP's high by feathering the clutch. It felt like a fuel pump issue, but I'm not sure why the gauges would stop working if that was the case? I haven't had time to get to it to see what's going on but, if anyone has any trouble shooting guides id really appreciate it. please help lol
2003 Coupe DX
Old Feb 16, 2021
Re: No RMP or Temp gauge, sputtering engine, stalling
check battery and alternator bolts (if they are tight). Ground wires too (3 of them)
and check if a critter did not get in looking for warmth and chewed your wiring
Old Feb 16, 2021
Update:
battery voltage 12.6 when car is off, voltage at 14.2 when car is running. Took a few times of turning over and giving it some throttle to get her started and revving up the RMP's for her to stay at a constant idle. Still no RMP or temp gauge. idled a little high but, the moment i give it some throttle it starts to bog down and stall.
Old Feb 16, 2021
check engine light on?
wiring ok?
Old Feb 16, 2021
Check engine light and maintance required light have been on since I got the car. Worth purchasing a OBD2 scanner??
Old Feb 16, 2021
yes.
get one from amazon, download app torque to your phone
Old Feb 16, 2021
Looking at the Zurich ZR11 from harbor freight. Little more money but worth spending for future problems I believe.
Old Feb 16, 2021
Colin42's Avatar
Yes...........................
Get a dongle from Amazon for $20 and the torque pro app for $5.
Old Feb 26, 2021
Okay, so couldn't connect to the ECU with my OBD2 sensor. Hooked it up to my friends corrola and worked instantly. ECU could be the problem right? I'm purchasing a remanufactured ECU unit to replace the old one, I've seen some guys replace the ignition with it as well. is replacing the ignition necessary? or do I just need to program the new ecu to my car? really could use the help, thanks guys!
Old Feb 26, 2021
7th gen have the immobilizer.
Key need to be programmed to ECU, locksmiths can do it.
Check if alternator bolts are tight - that is the usual cause of fried ECU
get ECU for same car year/model/transmission type.
Old Feb 26, 2021
BrotatoChip's Avatar
Super Moderator
Seriously, do this. It may fix all your issues without having to replace the ECU (if it isn't fried yet). Three mounting bolts on the alternator that you need to check: one on top of the alternator to mounting bracket, one underneath from mounting bracket to alternator, last underneath from bracket to engine block. The mating surfaces of the two underneath need to be clean (bare metal). The one that's usually missed is from the bracket to the alternator underneath. The adjustment bolt can still be used to keep the belt tight without that bolt tightened so people miss it.
Cesar27alexis
Electrical
Sep 5, 2023 04:44 PM
tim.ocallag
Electronics
Jan 3, 2020 08:41 AM
IronFist
Oct 29, 2003 06:32 AM
02NCcivic
Apr 17, 2003 08:02 AM
AFlyer
Jan 5, 2003 10:56 PM
