ECU Fried 7th Gen cars have a Chronic issue - alternator bolts get loose and the loss of grounding will eventually fry the ECU
Running rough after alternator work
Old Mar 15, 2021
04 civic black's Avatar
04 civic black is an unknown quantity at this point
Ok I have a 04 civic and the batt lite came on, so I figured it was the alternator had it tested and shop said it was junk, lol cause I replaced the battery a little less then 2 years ago, so I got the alternator fixed from a friend of the family and picked it up and it running like pos, almost stalled, seemed like I only had 3rd gear didn't shift atall only the spedo worked nothing else, barely made it home, putting down the road, lol, got home turned it off and the exhaust manifold was red hot smelt like exhaust fumes inside, I let it cool down tested the battery it was good, tried to put my scanner on it and it wouldn't link up, I was wondering if the computer may be fried, I don't really kno what to think, I kinda thot the cat may be plugged but it didn't act like that before the alternator was swapped, it's the weirdest symptoms I've ever seen, could really you some help...
Old Mar 15, 2021
Colin42's Avatar
Re: Running rough after alternator work
Bolts weren't tightened properly on the alternator, computer may be fried
Old Mar 15, 2021
How much do you think it would cost to reflash or fix the computer?
Old Mar 15, 2021
FRSam's Avatar
Click Here
If the computer is fried, you need to replace it. It'd be probably $40 to get one from a junkyard, not sure what it would cost to calibrate to the car - probably an hour or two of labor?
Old Mar 15, 2021
So if I found one at the junkyard it might work, it would probly hafta be the same year tho rite
Old Mar 15, 2021
FRSam's Avatar
Click Here
I don't think so. You'd probably have to match to your trim level, but the years shouldn't make a big difference. 2004 or 2005 should work.
Old Mar 16, 2021
If you have EX, need to be EX. If you have Si, need to be from a Si
if you have non-EX, use any others
Transmission - if auto, need auto ECU
you are going to need to program the keys to the ECU, or get the keys and ignition on the steering column that matches that ECU
Old Mar 16, 2021
Ok thanks guys
Old Mar 16, 2021
BrotatoChip's Avatar
Super Moderator
Get the alternator bolts fixed first. The ECU may not need replaced. There are three bolts that need to be tight: one on top of the alternator to a mounting bracket, one underneath going from a mounting bracket to the alternator, another underneath holding the mounting bracket to the block. Should also make sure the mounting surfaces are clean.
ms81
Feb 9, 2011 10:48 PM
Ichiban
Nov 18, 2006 09:15 PM
roger t
Aug 7, 2005 02:38 PM
gearbox
Jan 31, 2005 02:29 AM
burnhard88
Ottawa
Jan 1, 2005 03:41 PM
