Alternator problem need help fast
Old Nov 17, 2006
Ichiban's Avatar
Ichiban is an unknown quantity at this point
About a month ago my alternator died. I replaced it with a Autolite remanufactured one. Then today on my way home from work it died again. I checked all the fuses and all the wires inbetween the battery and alt seem fine. I don't know what else could be wrong besides I bought a bad alternator. Any ideas would help at this point. Thanks
Old Nov 17, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
are you dripping oil/other fluids on it..
in a past car i went through 3 before i noticed that only while stopping oil would drip differently off of god knows what and land on my alternator...
Old Nov 18, 2006
streetglower's Avatar
when you had the alternator replaced, what was the output of the old one?
When you say die, I think the car died and then you had to restart it. When the car dies, what is the battery voltage of the battery?
Old Nov 18, 2006
sql_civic's Avatar
I fried an alternator and starter until I replaced the shitty wiring that was run from the battery to the alternator by the previous owner. So check your wiring.
HiImBrandon
Jun 1, 2015 07:34 AM
jackoncruzpr
May 24, 2015 12:24 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
tylerginevan
Apr 27, 2015 12:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
