alignment question
Old Aug 29, 2007
blackout881's Avatar
blackout881 is an unknown quantity at this point
alignment question
Went to a bunch of shops to get my car aligned, but none can do it because of my wheels. I finally found a place that can, but they want $140. Would it matter if i put stock wheels on the front, got it aligned, then put my 17s back on? Just replaced my control arm, wheel doesnt quite straighten out when i let go and go straight..the car doesnt really pull much at all, but the wheel is like cocked about a 1/2"-1" to the right. Very annoying. Is there anything i can do to fix that besides alignment? Not even sure if i need one
Old Aug 29, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: alignment question
that sounds kinda strange. For some reason my alignment settings never hold and I am on stockers. Its pissing me off, so I feel your pain
Old Aug 29, 2007
svtec's Avatar
svtec is an unknown quantity at this point
Not sure about the steering wheel part but. alignments only run from $45-$85 at the most the wheels you have on should not matter.
Old Aug 29, 2007
TRIZ's Avatar
I had the steering wheel problem... tweak it by following my post over here: https://www.civicforums.com/forums/4...ml#post4228500
Old Aug 29, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
i just got my tokico hp and pro-kit installed last week...and im drivin around to get the spring settle... my steerin is crocked to the right to around 25 degree... the guy who install my shocks told me that i need to get aligment and it will slove the problem.. im gettin my aligment done this friday .. so.. i will hola back at u
Old Aug 29, 2007
ryox82's Avatar
I have that exact combo installed. we had a camber tool (basically a level with a magnet on one end) for the front and the wheel was perfectly straight and camber straight in the front after the drop. Camber is off a little in the rear and I am getting tons of wheel hop, like dangerous if i hit a bump. It was handling great until about a week after the drop. Wonder if toe in combined with camber could cause that.
Old Aug 29, 2007
VinhTEC's Avatar
VinhTEC is an unknown quantity at this point
When installing suspension just loosing a bolt can change alingment. Alingments dont stick normaly cuse of all the varibles in the suspension rubber bushings, worn bushingsleeves, weak springs ect. But the reason why some shops cant aling your car is because of the 17's some shops have older alingment racks and are not equiped for bigger than normal wheels and truthly most shops wont want to do alingments cuse they are afraid of damaging your wheels soo they will just decline you. Sorry good luck with your alingment!!!!
Old Aug 29, 2007
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
All the wheels should be the same sizes when doing an alignment, especially on the newer alignment machines that use infared light(like Hunter alignment machines). If you change your rim size you should always get an alignment.
Old Aug 29, 2007
it almost feels like the nut under the support arm that i just replaced is too tight, and if i loosen it a tiny bit it be more aligned with the other side, thats why i think my wheel is cocked to the right. ill try to fix it in the morning, if not then alignment.
Old Aug 30, 2007
buckshizzo's Avatar
If it's cocked to the right then it could be the result of the toe being out or the camber being positive. Something could also possibly be bent.
Old Aug 31, 2007
HighBoost's Avatar
well, my steerin wheel was crocked to the right ...i got my alignment done today... the guy have to adjust both side to make it "o" therefore, steerin wheel crocked to the right is not just affect by the camber IN MY CASE.
Old Aug 31, 2007
skipbarber's Avatar
sounds like too much toe in the rear.
as for the OP: camber wont affect the angle of your steering wheel so long as the toe is within spec. Ive never heard of a shop turning down an alignment for some 17's. even the old Hunter machines were capable of atleast 19" wheels. 17's have been a fairly common size for many years now.
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bsmiley
Aug 13, 2015 10:32 PM
civic98?
Aug 13, 2015 01:32 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
