Tie Rod Ends?!?
Old Mar 5, 2007
iGGY's Avatar
iGGY is an unknown quantity at this point
Question Tie Rod Ends?!?
Hey All,
I have an 05 EX (Canadian Si) which is lowered on F2 coilovers for a few months now. Just recently I've been hearing a clunking noise from the front driver's side when I go over bumps. It doesn't happen all the time, just sometimes. Could this be a bad tie rod end? How can you tell when the tie rod end is bad? Any help would be great.
Thanks
Old Mar 5, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
I could be, but it could also be just a loose bolt or the spring hat isn't tight enough against the top of the shock tower. Take a look around under there and see if you're bottoming out against anything. Then check all your bolts and look for oil or grease on everything. Then of course check for signs of rubbing/bumping. One of the 3 checks should yield your problem. Mine ended up being a loose upper strut bolt and it was just wiggling back and forth in the shock tower cup. GL with it man.
Old Mar 5, 2007
iGGY's Avatar
Thanks for the suggestion. I'll give that a shot tonight.
Old Mar 7, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
clunking noise, it could also be an endlink, which is for the sway bars. get under there and find out!
Old Mar 7, 2007
TRIZ's Avatar
I'd say endlink, but theres a slight chance it could be a blown shock, but you'd see fluid leaking like tuningmycivic stated.
Old Mar 7, 2007
TeLLy's Avatar
Yes, it's an Acura EL
Make sure all your perches are nice and tight too, that's the most common problem and most easily diagnosed/fixed.
Old Aug 29, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: Tie Rod Ends?!?
^ How do you tell whether or not the perches are tight enough?
Sorry for bumping a thread from the dead...
Sep 26, 2023 06:44 PM
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alwaysloyal360
Jul 29, 2015 02:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
17
Jul 23, 2015 11:48 PM
