Interior Post about Interior parts, seats, consoles, etc
Interior leak around dash
Old Mar 6, 2024
bluejello's Avatar
bluejello is an unknown quantity at this point
I've got a leak that shows up in the floor wells both driver and passenger side that started this past winter. The carpet in both wells is constantly wet and I'm able to see water running down the side of the door frame once the door is open as well as the outside of the dashboard where it meets the door. I originally thought it was being directed down from a split in the door seal, I had run some ratchet straps through it during the summer to hold down a kayak and figured that was the likely culprit especially as the leakw as on both sides. I replaced that piece on both doors though and am still getting water intrusion. Is this a common Honda problem that anyone else has dealt with?
Old Mar 6, 2024
Re: Interior leak around dash
common? no
Old Mar 6, 2024
BrotatoChip's Avatar
Super Moderator
Is the thin door frame above the window bent from closing on a strap?
I have a leak that shows up in a similar spot. Rust along the top of the window lets water in from the driver's side top corner. It runs down the back of the A pillar cover and finally shows up by the hood release.
Old Mar 7, 2024
bluejello's Avatar
Thanks for responding, I checked under all the weather stripping to see if it was deformed, but it all looks clean. Unbent and unrusted. I'm wondering if its coming from the cowl on my vehicle.
Old Mar 7, 2024
Super Moderator
I'm not talking about the metal being deformed, I'm talking about the entire window frame being bowed outwards preventing a good seal. Could easily bend it back if that's the case.
Sit inside the car and have a helper spray it down the the hose. You can attempt to trace down the source.
Old Mar 7, 2024
that is how they open a car without keys
julian_s
Interior
Aug 19, 2023 09:41 PM
Garceeli
Exterior
Feb 7, 2022 07:14 AM
RoseyEm2
Sep 27, 2017 09:38 AM
damoore
15
Feb 13, 2012 12:56 AM
Andrew
Jul 20, 2005 12:04 AM
