Water finding a way into the cabin 2002 LX Coupe
Old Feb 26, 2017
RoseyEm2's Avatar
RoseyEm2 is an unknown quantity at this point
I have water coming into my car and I don't know how or where all I know that whenever it rains my driver side carpet is always soaking wet. Any ideas?
Old Feb 26, 2017
Re: Water finding a way into the cabin 2002 LX Coupe
Last huge water leak I had to chase was caused by dried out body seam sealer (dried and cracked) just under the bottom corner of the windshield. Water would trickle right in when testing with a garden hose and watching up under the dash.
Sorry, no pics of the leak source......but it's a helluva lot of work to get the interior stripped, get the carpet lifted up and dried out so it doesn't mildew.
There are many possible places for leaks though....testing and inspection is needed.
Old Feb 26, 2017
RoseyEm2's Avatar
Well on the bottom.of my door panel it's sometimes wet and sometimes my speaker is wet could it be a window seal? But idk how that would result in a wet carpet. It has no connection.
Old Feb 26, 2017
The door is hollow, water is allowed to pass through it, it's designed that way....BUT
There is supposed to be a thin plastic liner (vapor barrier) sealed to the door covering the holes before the door panel is installed. If that's damaged, unattached or missing that can allow water to enter the cabin.
Random google image of vapor barrier
Old Feb 26, 2017
RoseyEm2's Avatar
Okay so what I did is I took off the door panel to find that it was taped down so I ripped all the tape off and I took some caulk and I lined it all around the door and made sure the liner was on correctly. And then I took off my feender to realize that the lining that is between the fender liner and the actual door was moving around so I cliped it back in place. Before all of this I took of the roof strips to see if there was something there like a drain that's clogged but there was nothing there it was just dirty so I cleaned that. Fingers crossed if I fixed it.
Old Feb 26, 2017
Next dry out the carpets... The padding underneath the carpet you can see can hold a whole lot of water.
If you didn't find the cause.....Get a flashlight and sit in the car under a sprinkler or have someone hose the car down, search to find where water actually enters.
Old Feb 26, 2017
Water leak car:
Seats stripped out, carpet lifted and held up with lumber, huge fan left on it overnight
Old Feb 27, 2017
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Originally Posted by ezone
Water leak car:
That is a nice fan. Bet it comes in handy for things like that.
Old Sep 12, 2017
Colin42's Avatar
Water leak car:
had to do this sunday
need to find the damn leak now
Old Sep 12, 2017
It's probably easier to locate the leak while the interior is removed!
Old Sep 13, 2017
Colin42's Avatar
Very true, I have a feeling it's the grommet for my aftermarket fog lights, that's the first place I'll check, then I'll start checking around the windshield
Old Sep 27, 2017
Colin42's Avatar
Grommet had fallen out, flipped it and glued it in with some rtv and smeared some over it for good measure. Need some rain now
