Leaking oil
Old Aug 28, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Leaking oil
I have this oil settle on the bottom on my oil pan to the transmission side . im wondering if its comming from down from between the transmission and the oil pan. Here is a pic.
Old Aug 29, 2019
Wankenstein's Avatar
Re: Leaking oil
When tracking oil leaks always start from the top down. Possibilities are valve cover gasket, cam seal plug (cap), Vtec solenoid gasket (if applicable) and rear main seal. While engine is cold use an engine degreaser, rags, and clean the area from top down as best as possible. Can use baby powder or athletes foot spray to help isolate the leak.
Old Aug 29, 2019
Re: Leaking oil
please start looking which section to post your threads.
I have had to move almost every single one of them.
Old Aug 30, 2019
Re: Leaking oil
Ok thank you.
Old Aug 30, 2019
Re: Leaking oil
I was thinking its the seal thats located between the engine and the flywheel.
Old Aug 30, 2019
BrotatoChip's Avatar
Super Moderator
Re: Leaking oil
Your pic is really hard to make out, if it were the rear main seal I would expect to see oil to the right of your finger I would think. Follow the instructions HR posted first.
Old Aug 30, 2019
colewan's Avatar
colewan is an unknown quantity at this point
Re: Leaking oil
Maybe the seal might be damaged
Old Aug 30, 2019
Re: Leaking oil
The one between the flywheel like i mentioned?
Old Aug 30, 2019
Re: Leaking oil
Since you cant see the pic clearly.i will try take another one tomorrow and post it ..
Old Aug 30, 2019
Re: Leaking oil
If it turns out to be the rear main seal that's leaking the engine and transmission will need to be separated to get to the seal. The part is cheap but it's labor intensive. Use Honda genuine seal only.
Old Aug 30, 2019
Re: Leaking oil
Ok..i can do it myself. I rebuild the engine put in head gasket and rings, also put 4 new barings in the transmission as well.
All i might need is a transmission lift. It give me a hard time to take out the transmission and to put it back in.
Old Sep 1, 2019
Re: Leaking oil
No need to remove the transmission from engine bay. A jack + a piece of 2x4" wood between the jack an transmission should suffice. Follow the service manual. YouTube's may help as well. https://m.youtube.com/results?search...rear+main+seal
Old Sep 1, 2019
Re: Leaking oil
Ok thanks.
tmst
May 28, 2017 02:50 PM
the dutchmen
Feb 5, 2017 05:06 PM
Execut1ve
Feb 5, 2012 08:42 PM
7thgenchris
Apr 25, 2009 09:50 PM
rolla
May 14, 2005 02:30 PM
