oil leak - front main or oil pan gasket?
Old Feb 5, 2012
Execut1ve's Avatar
Execut1ve is an unknown quantity at this point
Hello all,
I have a 2000 Civic EX (manual trans) with a bit of an oil leak. I changed the oil today and noticed quite a bit of oily grime on the driver's side of the pan, and a few driplets on the bottom. I tried to look up the side of the engine and see where it was coming from, but it was too tight in there for me to see much (i'm used to my big ford truck lol). from what I could tell, the oil seems to be coming from the front main seal area or I guess it could also be the oil pan gasket. I replaced the valve cover gasket at the last oil change, so I know that's good.
Any hints on narrowing down what exactly is leaking? How hard are those gaskets to replace? for comparison, I've done the oil pan gasket and rear main on my truck... pretty much have to remove the entire engine to get to it yay 4wd
Old Feb 5, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: oil leak - front main or oil pan gasket?
Take a picture. It's the best way. When you replaced the valve cover gasket did you seal the corners with the blue silicone stuff? If you didn't it's probably leaking from there.
Old Feb 5, 2012
Execut1ve's Avatar
yes I sealed the corners. you want me to take a picture and post it?
LionSpratt
Jan 29, 2017 11:07 PM
davidpaustin
May 20, 2015 12:59 PM
pheaton
May 4, 2015 08:26 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
