civic top speed continued
Old Dec 18, 2004
  #151
nindoo's Avatar
Why is my vagina bleeding?
Zzyzx is it diffucult to change the grearing on our cars to make them shorter? Is the easiest way to put smaller tires?
Old Dec 18, 2004
  #152
silver_surfer's Avatar
Pretty friggin old-school member
silver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of light
Originally Posted by AznChinksta
if all ur civics can go to 160 and up then all my friends with faster cars can top 200...
just stop speaking... damn
Old Dec 18, 2004
  #153
BigJim138's Avatar
BigJim138 is an unknown quantity at this point
I know this is my first post so ill prob get flamed or someting but isnt the gearing in the differential not the transmission b/c i had to get my rearend rebuilt on my cherokee b/c im so hard on it
Old Dec 18, 2004
  #154
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
its a combination. ur differential affects the final drive ratio. the final drive ratio is a combination of the gearing in ur differential and ur transmission.
Old Dec 18, 2004
  #155
S2000man01's Avatar
O RLY
no, the final drive ratio gear is a COMPLETELY seperate gear from the gears in your transmission. in layman's terms, it's basically the gear that seperates your drive shaft from the wheels.
big jim is correct. when people modify their car for quicker gearing (you've heard the term, putting in aftermarket gears) they simply change the FD. (so technically they are only putting in one gear) it's much cheaper and more effective to simply change the FD. for example, I can get an aftermarket FD gear of 4.44 or 4.77 for my S2000. it doesn't touch the transmission and simply changes the gear located in the diff. likewise, if you wanted to change your transmission gearing for some reason, you could do so, and your FD could remain the same.
Old Dec 18, 2004
  #156
S2000man01's Avatar
O RLY
either put on smaller tires, or change your FD gear.
Old Dec 18, 2004
  #157
BigJim138's Avatar
jw how much would that cost to change your fd gear?
Old Dec 18, 2004
  #158
right, but doesnt the differential and ur tranmsission combine to produce ur final gearing that is considered when racing?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
CIVICINJEN
Nov 4, 2001 06:04 PM
