civic top speed continued
Old Dec 14, 2004
S2000man01's Avatar
O RLY
I figured we can start a new thread, rather than have to sift through 17 pages of posts of which more than half were from 2002.
People want to know the top speed of the civic. I'm pretty sure it's governed, but at what speed seems to be a debate. However, I can pretty much gaurantee you that it's governed somewhere before 130mph. why? because a civic comes with H-rated tires, which have a safe top traveling speed of 130mph. It would be (if memory serves me right) illegal for honda to sell a car that was not governed at a speed that is BEFORE the rated safe speed for the OEM tires.
Now since this is done by ECU it probably doesn't go by rpm in your 5th gear (or 4th for autos).
Now... let's say you could remove the speed governor limit and actually get a ton more HP into your civic. What is the ceiling then? (with stock tires)
here you go:
manual EX, top speed is 159mph
AUTO EX, top speed is 176mph
now you EX owners are gonna be pissed.....
manual LX, top speed is 167mph
AUTO LX, top speed is 177mph
(oh and since it's interesting to me, an S2000 top speed is 174. fortunately they aren't governed at all, so all we'd need is a few extra hp to get us there, since the car is drag limited at about 164mph)
k, have fun kids.
Old Dec 14, 2004
zachgeyer's Avatar
hum yea
Old Dec 14, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
really? i dont think ur LX auto is correct. i mean im revving at around 4500rpm when my speed limiter kicks in at 112 i dont see how i could get another 65mph out of 2300rpm.
Old Dec 14, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
a really big hill
Old Dec 14, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
/me cannot beleive his LX Auto will ever go anywhere close to 177 mph = 284.853888 kph
the f uckin H would probably fall off at that speed :P
im glad I smell a bit of sarcasm in this post
My car gives me a kind slow the f uck down right as I hit 180
Old Dec 14, 2004
S2000man01's Avatar
O RLY
let me check the numbers again. maybe i added a 0 somewhere. lol
EDIT:
i double checked the numbers and yes it's right. in fact, your 3rd gear tops out near your speed limiter, so my guess is you auto LX's hit your top speed pretty much in 3rd, and then the car shifts to 4th. (kinda like an LS1 camaro or firebird)
the 4th gear on the lx is REALLy tall (0.674) so yes it's perfectly believeable that it could wind to 177mph.
also do you have stock tires on?
Old Dec 14, 2004
TemjinX2's Avatar
i wonder how long it would take to get up to those speeds though..lol
Old Dec 14, 2004
S2000man01's Avatar
O RLY
lol well you'd be drag limited probably around 125mph anyways, so unless you've got a lot more power (and remove the limit set by the governor) you could be at it til you run out of gas and you'd still never get there.
Old Dec 14, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
wow 176mph id have to have 400+ hp and like no interior whatsoever to get there i think the car will start to fall apart after 150mph lol civics can't handle that much speed
this is one of the things u have to see to believe
Old Dec 14, 2004
nindoo's Avatar
Why is my vagina bleeding?
I can understand why the LX could go faster without the governer I think the EX has a shorter final drive ratio.
Old Dec 14, 2004
lose canon's Avatar
lose canon is an unknown quantity at this point
its funny how it says top speed of 240km/h on the dash but can't get anywhere close to it.
Old Dec 14, 2004
PunkingCivic's Avatar
I need TP for my bunghole
This morning I raced a early 90's hatch back civic on the freeway.
and the speed governer kicked in at about 115/120 in fifth gear.
Old Dec 14, 2004
nindoo's Avatar
when you guys say govener do you mean the redline, cause I've pretty much redlined in fifth gear at a little over 125mph.
Old Dec 14, 2004
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
limiter... mine kicked in at like 115 auto lx... not redlining...
Old Dec 14, 2004
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
limiter kiks in at 110 for me
Old Dec 14, 2004
dariusld's Avatar
dariusld is an unknown quantity at this point
My LX manual cuts out at 115 MPH or is it 110 MPH, Ive only done it once.
Old Dec 14, 2004
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
straight out of the 2002 civic manual:
Engine speed limiter: If you exceed the maximum speed for the gear you are in, the engine speed will enter the tachometers red zone. if this occurs, you may feel the engine cut in and out. This is caused by a limiter in the engines cmputer controls. the engine will run normally when you reduce the rpm below the red zone.
to understand why certain civics cut off a different speeds, one needs to know that the different civic engines run at different rpms to achive the same speed. Say an EX runs at 4K at 80mph and a LX runs at 3.8k at 80mph. If the speed increases proportionately to the rpms, the LX will redline at a higher mph. the type of tranny also changes the top speed before the limiter kicks in since 4th gear in an auto will have a different gear ratio compared to a 5th in manual. ok thats what i think...
Old Dec 14, 2004
Zzyzx's Avatar
Autocross Junky
Yup, but! although the LX could technically go faster... The EX would get to its top speed quicker.
Old Dec 14, 2004
nindoo's Avatar
And our engines sound much better doing it too. After 4 k rpm I love how our engine snarls. Its not your average ecno box.
Old Dec 14, 2004
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
hmm, i haven't hit the limiter in 5th yet...125+ mph. (01 EX manual)
Old Dec 14, 2004
Ledbelly's Avatar
Im the man in the box
When in a civic will you need to go 170mph ?
Old Dec 14, 2004
gh0st's Avatar
TAQUITOS!!!!
^^^ never
Old Dec 14, 2004
hustlelikem0fo's Avatar
when you see vin diesel's RX7 in your rear view mirror
Old Dec 14, 2004
S2000man01's Avatar
O RLY
that is your REV limiter. NOT your speed governor. engine speed is to prevent you from going beyond the safe amount of revs for your engine. has nothing to do with the speed limiting governor
Old Dec 14, 2004
skiboard's Avatar
Its gonna take long time before you hit high MPH
try it your self, floor your gas! after 90MPH, speedometer moves really slow and if you have a counter wind or uphill, I dont think you can even continue with 115 HP engine
Old Dec 14, 2004
Juan Solo's Avatar
Juan Solo is an unknown quantity at this point
Hmm, now that IS interesting. I never knew there was a difference. Or I guess I never really understood rev and speed limiters.
Good post by the way.
Old Dec 14, 2004
NoFriends's Avatar
I like ruining your threads.
02 LX - Governed at 117-118mph with 17" Wheels 215/45/17 tires.
Old Dec 14, 2004
zachgeyer's Avatar
lololololol *** too much man
Old Dec 14, 2004
jttegx's Avatar
OMNES AD UNUM
ex auto <---- 114mph. chills around 4-5k rpm and barely goes any higher.. unless you give me another 5 miles then maybe it'll get to 118mph or so.
Old Dec 14, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
How is a civic coupe or sedan not an average econo box? It might be considered slightly above the AVERAGE econobox, which I consider to be a Ford Focus, Nissan Sentra, Dodge Neon area.
