civic top speed continued
#121
Rep Power: 286 bgoetz alright thx i just wanted to be sure i got exactly what he meant.
and as for the whole thing of a saturn going 200mph... do you think that was with a stock tranny and that they didnt modify any other parts or replace any other parts... if your talking about salt flat speed records or something like i think you are. those cars are like funny cars when you break it down to stock parts theres barely any left.
bottom line is there is no way our car could handle those speeds, unless you modified it to do those speeds in which case this topic is friggin ridiculously unnescessary because i would hope everyobody knows that anycar in the world can go 200 mph if you " modify " it to get there.
#122
Riceburners Bitch
Rep Power: 0 hey on a side note i used this calculator to figure out my approximate top speed since my speedometer only goes to 120 (i guess i only have 120 hp accourding to the one guys dumbass buddies) anyway using the calculations on the chart i have hit 140 mph in my pickup truck lol and it was really stable
#123
Rep Power: 286 and if you want a few parts ... well chances are youd need a buttload of hp and tourque to get our cars to 170 so unless you baby it youd be smart to replace axles because they could snap, also the body would twist in ways a rubber band cant even twist if you got that fast (please dont take my exaggeration serious cus i know someone will), also theres plenty of bearings which i dont think are designed to be put to that stress inside the tranny and other places, and im not saying honda doesnt make good parts i love honda its that they dont make a part stronger than it has to be because that would cost them more money and car companys are all about making money. if you really want me to ill talk to a guy that has been completely dismantling and repairing and rebuilding auto trannies and manual trannies for like 35 yrs. (thats all he does everyday) ill ask him if a honda civics 5 spd could withstand 180 mph or so or if it could handle the hp it would need
#124
The Beez Kneez
Rep Power: 290 this thread has turned into a rediculous aguement.
this is retarded there is no way in hell a fking ex or any civic will reach 170mph.
but im not an idiot this is relative to moddification of course.
the original thread was about a stock civic. :GAY: (oh there is no icon for that well you get the idea)
this the **** that domestic and higher end car owners laugh at import owners about
#125
Rep Power: 296 i agree people are missing the point of s2000. He's sayin the tranmission is designed to go up to 180mph based on the gearing. The gearing is probably less aggressive to save on gas. In real terms, i think a stock civic tops out at about 120-130mph. I've hit 120mph on my ex auto civic at 6k rpm with aem sri. When i was alone on the 5 driving from north cal to so cal late at nite. It makess more sense that our cars are rpm governed rather speed governed considering a rpm governator would protect the engine from damage when you over rev.
#126
what debate. there isn't a debate. lol
maybe not with you its not a debate, but it is with these other boneheads that wanna refuse to believe that atleast some of the EX's are not speed governed.
#127
Addicted To Boost
#128
O RLY
Originally Posted by ncirom2003
(im curious as to what calculations you did exactly...-not tryin to be a ****-)
no... it wouldn't. i think people are missing the point that your overdrive gear (4th for auto 5th for manual) is a VERY tall gear.
it's a simple math calculation people. it's plain old fact. i'm not just pulling these numbers out of my ***. ****, plug the numbers in yourself.
http://www.mysportscar.com/tools/topspeed.htm
the EX for example
tire width: 185
aspect ratio: 65
wheel diameter: 15 inches
rev limit: I put 6800rpms to be safe
overdrive gear ratio: EX manual is .757 (this is your top gear.... 4th auto, 5th manual)
final drive ratio: 4.11
hit calculate.... 159mph for a stick shift EX. that's what your 5th gear will top out at (or close to that) if you could remove the speed limiter and had enough hp to get that high.
the EX for example
tire width: 185
aspect ratio: 65
#129
O RLY
to get there, you'd need some more hp (ala turbo), remove the governor, better tires, and that's pretty much it. you might wanna do some suspension tuning to help you drive the car at the higher speed.
you dont need to make a civic a funny car to get it up to that speed.
#130
O RLY
#131
O RLY
#132
1 Post
Rep Power: 271 Why can't someone put an EX 5-speed on the dyno and run it to redline in 5th gear and i guarantee you it will get to around 150 or whatever that calculated number is on the speedo. Air resistance wont' be a factor and you can see what the top speed would be with no resisting forces besides the friction on the dyno. Someone try that if theres a dyno that will handle speeds that fast.
#133
O RLY
Rep Power: 376 you'd have to remove the governor first. also, i dont think most dynos will let you run a car to 170mph on their dyno.
#135
1 Post
Rep Power: 271 I don't think EX's are speed governed because alot of people say they have gotten them up to 130 or higher. I think the only governor is RPM fuel cut off which would act as a governor in EX's in 5th gear.
#136
you underestimate the honda. do you realize, for example, the stock honda crankshaft can withstand 600+ hp? trust me, if you slap on a turbo and remove the governor, the car isn't gonna "fall apart" or suffer any damage from going to 170mph.
#137
Rep Power: 0 heres a question. if our cars were gear differently, lets say to max out at 130 or 140, if u use the same calculations, wouldnt they actually run the quarter faster? and just in general be quicker in auto-x and stuff like that?
#143
Autocross Junky
Originally Posted by bgoetz
to a point it would make it quicker, but then your final gear would be shorter and top speed less. And that is why there are 6 speeds for shorter gearing and a good overall high end
actually a 6 speed is used to shorten the gears for quicker acceleration (by keeping the engine in its powerband) the 6th gear is typically simmalar to a 5th gear on on 5 speed transmissions.
Example
RSX-S 6 speed gear ratios.
1st = 3.267
2nd = 2.130
3rd = 1.517
4th = 1.147
5th = 0.921
6th = 0.738
RSX Base 5 speed
1st = 3.267
2nd = 1.880
3rd = 1.212
4th = 0.921
5th = 0.738
notice that the RSX-S's 5th and 6th gears are the same as the 5 speeds 4th and 5th...
so ricergribbs is right, Shortining the gearing would improve acceleration, at the cost of top speed. which is why I run "Short" tires to alter the final drive ratio of my car, effectivly shortining the gear ratios = better acceleration
another example... The Lotus Elise has an official top speed of only 135 MPH.... But it gets there real fast.
#145
Example
1st = 3.267
2nd = 2.130
3rd = 1.517
4th = 1.147
5th = 0.921
6th = 0.738
RSX Base 5 speed
1st = 3.267
2nd = 1.880
3rd = 1.212
4th = 0.921
5th = 0.738
Example
1st = 3.267
2nd = 2.130
3rd = 1.517
4th = 1.147
5th = 0.921
6th = 0.738
RSX Base 5 speed
1st = 3.267
2nd = 1.880
3rd = 1.212
4th = 0.921
5th = 0.738
#146
O RLY
edit: i see this has been answered
#149
Rep Power: 286 Calculate the theoretical top speed of your car neglecting rolling resistance, wind drag, and other variables in real world physics.
this is the first sentence on that page.... those last three words are enough for me
#150
O RLY
Rep Power: 376 right... in other words, calculate your top speed based on gearing, wheel circumference, and redline. they put in the part about drag, resistance, etc, because you'd need enough hp to get to the top speed in the first place.
