Problems with new instrument cluster
Old May 27, 2018
sgt snazzy's Avatar
sgt snazzy is an unknown quantity at this point
Today I installed a new instrument cluster for my '97 CX Hatchback, I was looking for a cluster with a tachometer. The old cluster's speedometer wasn't working so I assumed it was either the speed sensor or the speedometer itself. The good news is I now have a working tachometer, the bad news is my speedo still isn't working and now my blinkers don't either! I'm not sure if this has anything to do with it, but I also installed a new windshield wiper switch (as the previous owner broke off the stalk). I'm trying to troubleshoot the problem with the speedometer right now. As for the blinkers I have no idea.
Old Jun 3, 2018
99stockcivic's Avatar
99stockcivic will become famous soon enough
Re: Problems with new instrument cluster
Any way you could have just not put the connectors back in tightly? Speedometer, if it's not the plug, can you check the codes and see if there is anything, because I would think a speed sensor would be my guess on that one, and it needs to be replaced. The blinkers make me think you should check the flasher relay.
This is to replace the speed sensor
andsmi
Jan 16, 2013 09:32 PM
ryrex02
Dec 13, 2010 12:34 PM
DEX200K
Oct 10, 2010 08:05 PM
onefunkyfreshdj
Aug 16, 2007 11:23 AM
Goatboy
Nov 17, 2005 09:02 PM
