Speedometer won't return to 0 ("bounces")
Old Nov 2, 2012
andsmi's Avatar
andsmi is an unknown quantity at this point
2005 VP Civic
Speedometer decides to jump to 80/90 -- then "works" with 80/90 as 0...sometimes it moves back.
I can actually "force" it back sometimes by "switching" the ignition to "on" position then off "repeatedly" it moves back about 3mph each time -- gets it back to 0 -- probably not a good thing. I've only done this a few times. It will then usually work fine for a short period (10 minutes to even a hour or so once)
So with speedometer at 100mph as 0 I ran the DIY cluster test -- everything tested fine but speedometer of course didn't return to 0.
I did the "hack" noted above to get speedometer back to 0 -- then ran the DIY cluster test again. Everything worked fine, even speedometer doing a full sweep.
I repeated the test a little later to show someone-- at this point during speedometer sweep it made it to got "jittery" and made it to 40 as the new 0....
If I plug into the OBD-II and watch speed it reports fine.
After reading all comments around it sounds to me like I need to replace the instrument cluster -- I see one on ebay with 104k (I have 150k) and it's for a DX but looks the same and is supposed to fit my VP sedan.
Everything I see seems to imply it's a pretty easy fix (I've watched a few videos and such) -- a few screws, some plastic clips, and some wire harnesses to detach/reattach.
Would anyone like to share any other opinions/recommendations?
Old Nov 2, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: Speedometer won't return to 0 ("bounces")
That Civic is just itching to do some fast n furious racing, it's in it's blood I guess. It's mother n father had a lot of NOS genes.
But yeah with the OBD2 scanner, if it displays the correct speed then that tells me that the speed sensor and the wiring for the sensor is correct. The wiring for the instrument cluster or the cluster is faulty.
Old Nov 2, 2012
04 Honda Civic's Avatar
Pretty much what he said.
Connect to scanner and see whats up. Probably the gauge if you dont have a CEL.
Old Jan 16, 2013
lito99's Avatar
lito99 is an unknown quantity at this point
Ihave this SAME problem! My "zero" isright now at 25 (i get a kick out of my family jumping when they seeit read 100 when im at 75 XD anywho...did swapping out the gauge cluster fix it for you? Doing the key thing is annoying all the time lol
Old Jan 16, 2013
Again, everyones problem is different.
Hook up a scanner to it. If the VSS reads zero replace the VSS.
If it reads the actual speed replace the cluster.
FutureCivicOwnr
Aug 11, 2015 10:59 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Jul 12, 2015 11:54 AM
