Speedometer stuck at 18 mph
Old Oct 10, 2010
DEX200K's Avatar
DEX200K is an unknown quantity at this point
`96 sedan, 344,000 miles, speedometer stays at about 18-20 mph even in park or neutral. Sometimes it starts working after 10 minutes of driving or when sitting overnight. No MIL or check engine codes so it would seem to be a mechanical speedometer problem. I looked in Haynes and the Honda repair manuals but they only show how to take out the instrument cluster panel. There is no speedometer cable going into the instrument cluster!! Where do I look?
Old Oct 10, 2010
lazlong's Avatar
Re: Speedometer stuck at 18 mph
Either a bad speedo or VSS (vehicle speed sensor). Can get the speedo pretty cheap at the salvage yard. VSS you need to get new. Here's a link to some places to find parts: https://www.civicforums.com/forums/8...ead-first.html
Old Oct 10, 2010
DEX200K's Avatar
I hope it is the speedo and not some wire short. I had an extra VSS so I put that in but still the same stuck speed needle at 18 mph.
How do you get to the speedo? It looks like it's beneath a flexible circuit sheet or inside the plastic case of the instrument cluster? Beside the circuits, all that's back there are indicator light bulbs.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Munzy
21
Oct 7, 2015 07:48 AM
260000milesgoal
Sep 25, 2015 07:41 PM
MamaBear2015
Sep 15, 2015 09:35 PM
