SRS light on and no horn
Old Jun 16, 2009
grubby's Avatar
grubby is an unknown quantity at this point
We had an accident and the front end was repaired. When we got the car back, the SRS light was on and then I noticed the horn didn't work. Can anyone make some suggestions about how to fix this? My insurance won't pay to have this corrected.
Old Jun 16, 2009
TRIZ's Avatar
Re: SRS light on and no horn
Who's ever fault it was should be the ones to repair it. If they dont, you can take legal action on them. The srs light being on means either they did not reset the light (search RESET SRS) or there is a fault somewhere in your system- meaning an airbag is show as deployed or the seat doesnt have the SRS equipment connected, etc.
As for the horn, its between the grill and the drivers side headlight under the crash rail. Check that its there, that its connected, and that the fuse isnt blow. After that, you need to check with a multimeter that current is getting drawn.. if its not, replace, if it is, you need to trace the wires and find the problem.
Old Jun 16, 2009
CraigW's Avatar
Did the air bags deploy ??
If there is a problem with the clock spring in the steering column it could cause both problems.
Do you hear a click noise from under the hood when attempting the horn ??( from horn relay)
Old Jun 18, 2009
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Thats what I learned in school, is that if you are having both problems at the same time, its probably your clock spring. I think craigw is right
Old Jun 29, 2009
grubby's Avatar
Thanks to all for the replies. I am going out to check on the horn in a minute. As for the Airbags, no, they never deployed. It was a relatively minor fender bender but the fender and clips were replaced as well as the passenger-side headlight.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
