Wiring Neons...need help..............
Old Jan 22, 2009
BigVic4545's Avatar
BigVic4545 is an unknown quantity at this point
Wasss up peoples...i have an 02 coupe ex....i currently have 2 12" NEONS under both front seats wired up to a switch and ****.. What i would like to do now is wire them in a way that they only light up when i open the doors....its like when you open the door and the dome light comes on.....does anyone know what wire i would have to tap into??? and exactly how would i have to wire it...im pretty good at wiring so just let it out...thanx guys
Old Jan 22, 2009
supafil25's Avatar
supafil25 will become famous soon enough
Re: Wiring Neons...need help..............
if you were good at wiring then you wouldnt be asking this. run a wire from the dome light to the neons or from the fuse of the dome light.
btw neons = RICER lol
Old Jan 23, 2009
BigVic4545's Avatar
Since when are neons under you seat ricey?? Besides i can do whatever the hell i want with my car...i have a dam k swap..it's not like im trying to be fast..im already fast.
Old Jan 23, 2009
ya who cares? i have red lights under the seat but theyre leds. for dome light it was a real pain and what i ended up doing is tapping the wires right at the actual dome light. i tried all the wires in the driver side pillar and couldnt find the right one. when you remove the dome light assembly you will see the wires underneath. the hard part is running new wire from there down to the neons.
Old Jan 23, 2009
BigVic4545's Avatar
yea..basically the only way i see it..is running the wires from the dome lights through the headliner and down through that plastic piece near the visors that comes off..thats gonna be a pain though..anyway thnx GearBox
Old Jan 24, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Anyway you can actually hook the LED's or Neons up to the door nipple?
Old Jan 24, 2009
TRIZ's Avatar
Use a relay.. tap the dome light to activate the lights.. if you need more power, then tap off the dome light. I've been meaning to do this... I have the lights too, but just couldnt find a decent mounting location under the front dash where you couldnt see them.
Old Jan 24, 2009
door trigger is setup differently. theres only one wire to the nipple and the actual piece is grounded to the car body. and i think the polarity is reversed. i think it stays on when the door is closed or something and turns on when open.
Old Jan 24, 2009
civicplaya's Avatar
Okay because i was wondering if you could just hook them up to the door nipple because if you haven't read my other posts, my dome lights don't turn on when i open the doors, which i guess is because I don't have the stock head unit.
Old Jan 24, 2009
TRIZ's Avatar
Your headunit shouldnt have anything to do with if your dome light comes on or not... did someone hook up your headunit that had absolutely no idea what they were doing or something? Is the bulb burnt out.. use an voltage meter to check if there is any current going to the dome light wire when door is opened/closed.
On topic... yet slightly off... can you guys post pics of exactly where and how you mounted your lights (if under the dash for the footwells of the front seats) ...maybe I need to ditch my neons and get a flexable strip of leds?
Old Jan 24, 2009
civicplaya's Avatar
According to all the posts on this form, that's why my dome lights don't turn on when i open the door. I guess because the stock headunit controlled keyless entry and enabled dome lights to turn on when door opens.
Old Jan 24, 2009
CraigW's Avatar
He has a 6th generation.
Old Jan 24, 2009
BigVic4545's Avatar
im gonna try tapping into the dome light tommorow morning and i'll let u guys know how it went.
Old Jan 25, 2009
supafil25's Avatar
id like to see a pic of this k20 in your car.
Old Jan 25, 2009
TRIZ's Avatar
Oh... Didnt know ya had keyless entry.. I dont, so... yeah. I'm done here. Goodluck.
Old Jan 25, 2009
civicplaya's Avatar
Haha actually i don't have keyless entry. It's just the dome lights don't turn on when i open either door because i don't have the stock head unit- told from multiple people on here that's why....
I just need to figure out something
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
