diy: my throttle body heater bypass (pic!)
Old May 25, 2005
  #211
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Attention!
I bought the universal plastic hose connector from my local auto parts store. It worked great until I started driving hard in 100-degree weather here. In such hot conditions, the center plastic cylinder becomes detached from the "nipples" on either end. This may be because they glue the plastic connector together and the glue melts, or it may just be weak areas in the connector. If caught mine in time before it sprung a major leak. If you used a plastic connector, make sure you check it after you're engine's hot to see if it's holding together.
Old May 25, 2005
  #212
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
just make it one continuous hose like I did. A little bit of work, but at least you wont have to worry about all these problems and it's free. Just my $.02
Old May 25, 2005
  #213
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Amen brotha
Old May 25, 2005
  #214
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
wouldnt it also work if u just a small enough hose to use instead of copper or plastic tubing? it would helluvalot better than a plastic or copper tubing wouldnt it but just need to b strong enough to fit nice and good between the 2 tubes.
Old May 25, 2005
  #215
...ever grinning...
This seriously needs to stop before someone get's coolant all over their engine bay or gets **** flowing inside their cooling system. I FIRMLY believe that the only way to do this is to just connect the nipples on the motor. Save yourself the potential problems and just do it right!
BTW Gearbox, how is your Typhoon? Did you get it yet? I just bought some things off of silvercivic including an eBay long-ram with an AEM filter. I'm only using the short ram tho since the long is uselss in our cars. But I defintely feel sumthin more up around 4000+ with minor drop under 1700. I don't know why people say cai's are useless on our cars... But let me know about your Typhoon system cause I read about it in my Super Street magazine and on a stock STi it generated 7.4 whp and 3.2 wtq.
Old May 25, 2005
  #216
i'm so sick of this. The plastic will melt? I sure hope not. There is no way I can reach down there. Is there a clamp or something that can go to hold both ends together in case something happens? It's only gotten to around 70 here and no problems. But coolant spilling would be very bad. I'll keep an eye out. This is gonna be much easier to work with once the typhoon gets here in about a week.
Old May 25, 2005
  #217
...ever grinning...
Why can't you reach down there? If we meet up somewhere and it's daylight I'll help you do it cause I don't want you having problems. All you need are some long needle nose plyers and either the stock clip or some small hose clamps.
Old May 25, 2005
  #218
ya I have long thin pliars, but I can't get a good grip. And my hand doesn't fit down there. Oh well. We'll see what happens. Maybe at the next meet in chicago you could help me out
Old May 25, 2005
  #219
...ever grinning...
Definitely. Do what you want, but for now I'd leave it stock so you don't have that coolant spray...
Old May 25, 2005
  #220
well I'm gonna need new hose. Maybe I can reach it better once everything comes apart for the intake and tb.
Old May 25, 2005
  #221
...ever grinning...
You never took of the air cleaner box?
Old May 25, 2005
  #222
born2xLr8's Avatar
my plastic hose connector is holding up alright and temps have reached over 80.
Old May 25, 2005
  #223
...ever grinning...
Not worth risking it IMO. Plus it looks alot more professional with stock looking hoses on there instead of 2 hoses connected by a plastic piece, especially now that your getting a typhoon all that stuff is visible.
Old May 25, 2005
  #224
crazyasian's Avatar
i tried looking for some hoses at my local auto store and found the hose size that i needed but they arent long enough. where did u guys get your hoses so that its just one single one from one end to the other. also did u guys have coolant coming out after u took off the hoses when u were replacing the current 2 hoses to one single one. im pretty sure there would b coolant comin out. what did u do to not make a mess.
Old May 25, 2005
  #225
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
yeah the rear hose will leak. I spilled alot yesterday. The hose I put in is to thin I need to put a thicker hose in.
Old May 25, 2005
  #226
...ever grinning...
Go to a carquest cause they got fuel line on a reel that you buy by the foot. I think i got like 14-15" on my car right now. I kinda made a mess, but inbetween attempts to put the hose on the back I held my finger on it. The front should only do a few drops if you let it cool down for a few hours.
Old May 25, 2005
  #227
crazyasian's Avatar
prob best to do it when cars cold so your not scolded with hot coolant. trying to find a place where they can supply long enough tubing. so far 5/16 tubing works
Old May 25, 2005
  #228
...ever grinning...
I used 3/8 fuel line. And I capped off the TB really tight with 1/4 fuel line.
Old May 25, 2005
  #229
crazyasian's Avatar
how long is it from the front inlet to the rear inlet? wat length hose did u use?
Old May 25, 2005
  #230
Redline04's Avatar
ok don't know if you missed my post but I used the stock hose clips and the hose that is connected to the front inlet. It is long enough to reach and fits perfectly into the stock clips to hold it in place. When you pull the rear inlet hose off coolant will squirt out quite rapidly, so be prepared to slip the front inlet hose on there quick. Like someone else said you can put your finger(if you can fit)over it to slow it down.
You don't have to buy anything except some vacuum caps to cover the outlets on the TB.
short hose that was removed
Old May 25, 2005
  #231
I have those same caps on the tb inlets. However in your pic, I didn't have all the room you did. There were other hoses blocking it in.
Old May 25, 2005
  #232
Redline04's Avatar
maybe 04's or DX is different?
Old May 25, 2005
  #233
...ever grinning...
Same here... mine is deep in there. Looks like the 04+'s nipple is practically on the TB.
Old May 26, 2005
  #234
Redline04's Avatar
mine is too, pic just isn't that great. The hose with the white stripe is the hose we are talking about. Just right of that big one in the last pic. Down behind some ther stuff. Very Tight!
Old May 26, 2005
  #235
...ever grinning...
Ohh... I see it now. Wrong hose...
Old May 26, 2005
  #236
Redline04's Avatar
maybe this pic will help you see better?
If the hose origionally connected to the TB it should be long enough cause the rear inlet is closer.
Old May 26, 2005
  #237
crazyasian's Avatar
i guess i would have to pry away the silencer but then again i might b wrong. i do believe i can still get to it without pullin it off. i never thought that hose was long enough.
Old May 26, 2005
  #238
...ever grinning...
No way... Take off the ENTIRE induction, that is the absolute easiest to do this. Otherwise you're taking up usable arm space.
Old May 26, 2005
  #239
crazyasian's Avatar
aite. cool. ill prob try this tommorrow or just wait for the weekend.
Old May 26, 2005
  #240
Redline04's Avatar
yeah I guess it is easier with an aftermarket intake. Soryy didn't relize you guys had a stocky. Probally have to take it off to do this.
