diy: my throttle body heater bypass (pic!)
Old Jul 20, 2005
  #331
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
I've had it set up for a couple months, no probs here, did the old tube switcheroo. Auto in MD
Old Jul 20, 2005
  #332
i put it back to stock and really there isn't much difference. Maybe it doesn't help as much as it might seem. Well I drove around and nothings leaking at least. Has to spend some time getting air bubbles out again and coolant slipping all over at first.
Old Jul 21, 2005
  #333
PunkingCivic's Avatar
I need TP for my bunghole
someone should do a tempature test with and without the bypass mod.
Does anyone have a INFRARED LASER THERMOMETER ?
Old Jul 21, 2005
  #334
7thGenerasianCivic's Avatar
i do
Old Jul 21, 2005
  #335
Originally Posted by 7thGenerasianCivic
i do
be our tester in the hot cali weather
Old Jul 22, 2005
  #336
This is dumb but interesting. Someone was talking about filling your windshield washer fluid reservoir with ice water and running one of the hoses that goes into the nozzles into the the throttle body instead. When you use the "squirt" you'd be cycling ice water through your throttle body. I'm not going to try this, but its funny.
Old Jul 23, 2005
  #337
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
hey that sounds like a pretty good idea. Dont know if would work though. You could run one squirter hose to the top port on the throttle body, then make a return hose to the washer resivour. Other qusetions, would the washer pump be strong enough to push it through and will running water through the throttle body damage that sensor that is supossidly in there?
Old Jul 23, 2005
  #338
the sensor is definately there. It even has a plug with wires coming off it (its the idle air control IAC solenoid). Well anyway I fixed my problem. Just put the coolant hoses back and reset the ecu. Now it idles alot better.
Old Jul 23, 2005
  #339
Redline04's Avatar
so what do you think about this idea of running chilled water through it? Would it make the idle really screwed up or damage somthing?
Old Jul 23, 2005
  #340
Nodnero's Avatar
Maybe Im stupid, but wouldnt running ice cold water into the throttle body would be a bad idea. Hydrolock anybody? I know it works with Intercooled (turbo) vehilces, I did that with my WRX, but I dont know about shooting it into the throttle body of the vic.
Old Jul 23, 2005
  #341
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
well there was antifreeze running through the same spot before and it doesn't actually get in the throttle body, it's just that it converts the throttle body heater into a throttle body cooler
Old Jul 23, 2005
  #342
Redline04's Avatar
Exaclty , but will it work?
Old Jul 23, 2005
  #343
i'm not sure how that sensor works. Maybe cold water might screw with the idle? There definately is no worry about putting water through there. It will only pass near the tb where air passes next to, not actaully go anywhere inside the engine.
Old Jul 23, 2005
  #344
booba5185's Avatar
the only thing i can think of to fix the sensor isue (when is happens) is to have everything hooked up like stock, run the car til it is at oper. temp, shut the car off, unplug the sensor take a multimeter, and check the sensor for what resistance it is, then go buy a resistor at that resistance, this is only an idea, i'm at work and cant see the sensor in front of me, but if the sensor only has 2 wires, then in theory, it should work....
Old Jul 23, 2005
  #345
well its actually a solenoid that closes when operating temp is reached.
Old Jul 23, 2005
  #346
booba5185's Avatar
k then nm, i'm a retard sometimes.
Old Jul 23, 2005
  #347
Redline04's Avatar
ok. I just pulled the washer hose off where it goes into the T splice on the hood and did some tests. First I drained the washer fluid. Then I poured some chilled water from the fridge in there. First problem I came across. Need to disable the wipers from coming on when u spray the washers. That would look pretty gay at the track or street. LOL Next issue is there enough pressure to push it all the way and back. It would seem so but the only way to find out is to do it I guess. While I was testing all this out I came up with another add on to this idea. Why not wrap hose all the way around the intake then put heat wrap over top then run in through the throttle body? Two problems with that. Again will the pressure be enough? And I found the water coming out the hose was a lot cooler then the hose itself so it wouldn't even cool the intake just by touching it. Make sense since the hose is rubber or whatever, conducts less heat. So metal would work better. So I grab my purge tube that I never put on and stuck it on the end of the washer hose. Ran the pump for a few secs and bam it was ice cold. Stayed ice cold for a few secs then was still cool to the touch after that. So some sort of metallic bendable hose would need to be wrapped around the intake for this to effectivly cool it. Then wrap the heat wrap over top to prevent the hot under hood temps from reversing the process. So In theory this would work if the pump is putting out enough pressure. It doesn't have to be a lot just enough to keep cool water circulating. I have seen somthing kinda similar with a coffe can wrapped with some sorta thin fuel line then ice dropped into the can. In this case instead of circulating the item being cooled around the cooling agent we would be circulatung the cooling agent around the item being cooled. Now I gotta find out where I can get some of that metallic hose and test this out. May or may not be worth it, but won't know until someone tries.
Any thoughts or opinions?
Old Jul 23, 2005
  #348
keep with the original idea. Putting heat wrap around the intake actually traps heat. I bought some expensive dei intake wrap and actually the intake tube felt hotter than before. Eventually the tube will heat up from all the engine parts.
Old Jul 23, 2005
  #349
This is funny. I didn't think anyone was paying attention. I'd like to see someone get it to work. Although, It really would only help people for a couple runs at the track, since there's no way to keep the water cold for very long.
Old Jul 23, 2005
  #350
Redline04's Avatar
Ask and you shall receive. Got it to work with a test setup but didn''t notice much but this could be due to the fact that I didn't have enough ice and the water warmed up quick. Check it out here. http://www.7thgencivic.com/forums/sh...69#post3224869
Old Aug 1, 2005
  #351
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Just to let everyone know, I'm still running strong with my single, direct hose. Is anyone who ran it like me having any problems? Also, is not having the coolant run through there gonna fry my IAC? I haven't had any problems at all yet...
Old Aug 1, 2005
  #352
there's a thread why this is a really bad idea. I have put mine to stock and all my idle problems are gone finally. The way the coolant runs, it actually only touches a small opening in the tb and doesn't pass any sensors. So the sensor should be fine but I still had idle problems due to the car thinking it wasn't warmed up enough.
Old Aug 1, 2005
  #353
booba5185's Avatar
did it affect gas mileage at all or did u even pay attention?
Old Aug 1, 2005
  #354
didn't pay attention but I doubt it. From what they figured in the other thread, it only raises intake air temps by 1-2 degrees. Not even worth doing.
Old Aug 1, 2005
  #355
...ever grinning...
Not worth doing? Damn, I remember when people were totally gung-ho about the whole thing. Did anyone actually do a dyno test with it? Cause I still remember when my car was stock and it got to temp it would run really sluggish, pretty much like accelerating with the A/C on full blast. But then it never ran like that since I did it... Gearbox, you got that thread handy?
Old Aug 1, 2005
  #356
Mine is fine, and I did the old hose switcheroo, so I'm guessing it's like yours, jester. But at least we know what the reason is if we start having idle problems. I'll put it back when I start rumbling a little more I guess, but my car feels pretty healthy lately, so I'm not going to change it for no reason.
Old Aug 1, 2005
  #357
http://www.7thgencivic.com/forums/sh...d.php?t=221119
Old Aug 1, 2005
  #358
...ever grinning...
Same here...
Old Aug 1, 2005
  #359
booba5185's Avatar
thats why i started this...or tried tooo......... http://www.7thgencivic.com/forums/sh...d.php?t=220727
Old Nov 18, 2005
  #360
01hx5's Avatar
01hx5 is an unknown quantity at this point
i'm lost
