Maintenance required light
Old Oct 4, 2010
  #61
Re: Maintenance required light
the maint reqd light is just a mileage timer and comes on at set intervals, even if nothing is wrong with the car. the headlamps of some 01-02 civics have a wire in the combo switch that can burn and cause the lo beams not to work. its actually a recall from honda. for oil, try checking the level after the car sits overnight. how much did you add last time? normally it takes around 3.2-3.4 qts. you might have massive oil burning and the level is way low.
Old Oct 4, 2010
  #62
grd00's Avatar
grd00 is an unknown quantity at this point
Gearbox - thank you for the info. I sent a link of '01 civic recalls to my friend and hopefully that clears the issue with the headlights.
We put 3 1/2 quarts in when we changed it last. I'll have her check the dipstick in the morning before she starts the car, see if she gets any better reading than we did yesterday.
Old Nov 16, 2010
  #63
Speedo's Avatar
Speedo is an unknown quantity at this point
For those who have not been able to get the light to go out, I discoverd last night that the process will not work if the headlights are on. Sorry if this was mentioned previously but I just figured this out last night. I was starting to think that the light required something special at 120,000 because I have always been able to reset it, but it seems you can't do it with the headlights on. Hope this helps.
Old Dec 11, 2010
  #64
leosar's Avatar
leosar is an unknown quantity at this point
thanks a lot
Old Apr 18, 2011
  #65
Stryfe's Avatar
Stryfe is an unknown quantity at this point
I was totally about to post about this. I'm a noob!
The light has been on for like a year too. I wish I'd looked this up earlier it annoys me all the time!
Old Apr 18, 2011
  #66
now that this thread came up from the dead, yes, this is true. I have aftermarket DRL installed in a US car (canadian rules...) - the darned thing simply did not allow me to reset until i took the fuse of the DRL off to reset the darned light...
Old Jun 17, 2011
  #67
liz92's Avatar
liz92 is an unknown quantity at this point
Originally Posted by gearbox
Nobody is allowed to post about this ever again! I will delete your thread no questions asked if I see it. You should know better than this. I will explain once and only once so that it doesn't get asked again.
Think of the light as a reminder. It has absolutely nothing to do with the condition of your car. It just comes on at certain mileage intervals programmed by Honda. The stupid ones rush to the dealer and get the $500 service pack which includes an oil change and inspection. Most of us here do that stuff ourselves.
The light flashes and goes off at first, but after a while it will just stay on. Again, so those that don't know will take it in. It has nothing to do with any of the recommended service intervals.
Turning off the light:
The answer is even in your manual! Hold down the trip meter button, turn the car to on, wait about 20 seconds, start the car, and let go of the button. Light is reset until the next mileage interval.
*make sure lo beam headlights are turned OFF during the procedure*
Posted by Metallica454:
This was soo helpful!! THANK YOU!!!
Old Jul 17, 2011
  #68
mililani's Avatar
mililani is just really nicemililani is just really nicemililani is just really nicemililani is just really nice
edit:
oops, never mind, I should have done a search first.
Old Jun 26, 2014
  #69
Rakakaa's Avatar
Rakakaa is an unknown quantity at this point
Hello everyone. New member, first time posting. I hope this helps.
Old Feb 13, 2016
  #70
Justin Bradford's Avatar
Justin Bradford is an unknown quantity at this point
What would happen if one was to leave the low beams in by accident? One if those things u say don't do and it makes me wanna do it. Ha-ha
Old Mar 7, 2016
  #71
SRCHN's Avatar
SRCHN is an unknown quantity at this point
Okay, now assuming my trip meter doesn't work....(hit the button to cycle between mileage and Trip A/B and nothing happens) am I out of luck? Any way to get this thing to turn off otherwise?
Old Mar 9, 2016
  #72
emich's Avatar
emich is an unknown quantity at this point
https://www.civicforums.com/forums/2...light-fix.html
Old Jul 13, 2016
  #73
Buckles1123's Avatar
Buckles1123 is an unknown quantity at this point
Ok, thats a ll fine and dandy but that only works if the trip meter button actually worked!.....is there a way around this that doest include using the trip meter?
Old Jul 14, 2016
  #74
Click the link in the post above yours?
or try this one
https://www.civicforums.com/forums/1...ton-fixed.html
Old Jul 10, 2017
  #75
Oakhill510's Avatar
Oakhill510 is an unknown quantity at this point
I have a 04 VP civic and just did a cluster swap from a 01 ex civic. The maint light won't turn off even after following the instruction on this page. I even hooked the cluster back to the EX civic and still the maint light won turn off. Suggestion?
Old Feb 28, 2019
  #76
Eljefe's Avatar
Eljefe is an unknown quantity at this point
I bought a 02 with the d17a1 car has 248k
one week later the engine spit parts out of the pan. I replaced the motor with a used healthy engine and had no problems for the first few days until this light came on.i tried what was mentioned but the light instantly flicks back on,is there other factors involved that im forgetting?.i obviously put brand new oil and filter once i re installed the engine.thanks in advance
Old Sep 6, 2021
  #77
Eward.Grand's Avatar
Eward.Grand is an unknown quantity at this point
My friend was threatened by the maintenance required light. She didn't know what to do with her old Honda when the light showed up. Even though I told her that wasn't a big deal as she just needed a check-up. I think the light comes on to remind us of the regular car check. I've read a pretty good article about this. Just wanna share with you all.
https://www.obdadvisor.com/honda-mai...t-does-it-say/
gearbox
Regular Maintenance
76
Mar 1, 2019 07:05 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
bakuretsu
Sep 24, 2004 08:31 AM
jkim1978
Feb 22, 2003 07:02 AM
RebeccaD
Apr 29, 2002 12:48 PM
