abs light in ex cluster?
YoUnG N SuXsExFul
i just a 2001 ex cluster for my dx...i was wondering where the abs light was cuz if i put it in the light will always be on...the cluster is just a direct swap right? no need to modify?
remove the clear panel and the black bezel from your cluster and you will be left with the bare gagues...lift up the top of the cluster, it just peels, and hold it up to light..you will see the ABS icon. grab a small piece of electrical tape and cover up that LED. its not a light bulb.
well, i know first hand because i had to do it. i have DX and i put EX cluster in my car. i tried to help, what you decide to do is completely up to you.
Skippo's right. I told him about the easy fix-that-abs light method. A lot of the things that light up inside the car are LEDs. I did it myself
why risk breaking your cluster trying to remove that abs light, when you can just cover that bish up? The leds aren't exposed either (not sticking out like keys on your keyboard); it's stuck deep in plastic parts of the clusters frame
YoUnG N SuXsExFul
yeah..i just took out the bulbs and put it near light..and it's not a bulb...thanks for the help guys..now i just need to open it up...it's just clips right?
Re: abs light in ex cluster?
^ I dont believe so- I think the white plastic back removes from the black face and you have access.
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
One_PeeJay
May 17, 2015 05:31 PM
bahena08
Apr 11, 2015 05:09 PM
