Engine swap
Old Mar 13, 2024
BubbleGumDumDum's Avatar
BubbleGumDumDum is an unknown quantity at this point
Engine swap
Hello everyone, so I’m looking for some assistance. I have a em2 manual, I plan on engine swapping and I came across a d16a6 that makes about 420 wit a turbo. Need to know what I would need to make this happen or if it’ll be worth it. I don’t want 420hp I’d be fine with about 300-350 so I’d turn the boost down. Owner says it handled 35 psi like a champ on E85. Do I need different engine mounts, ecu, harness, etc just lookin for some guidance.
Old Mar 13, 2024
Re: Engine swap
d16 is the previous gen engine, some states it is a no-no, check local laws. engines older than the chassis are emission issues.
moving out of suspension to Engine swap section.
Old Mar 13, 2024
Colin42's Avatar
Re: Engine swap
Look for a different engine. K series is basically your only option.
Old Mar 17, 2024
chozobody's Avatar
chozobody is an unknown quantity at this point
Re: Engine swap
Unless he wants to do some cowboy stuff 🙊🤠
Old Mar 17, 2024
Colin42's Avatar
Re: Engine swap
True but there'd be a ton of custom fab work that isn't going to happen
Old Mar 17, 2024
chozobody's Avatar
Re: Engine swap
yeah, you're not wrong
Old Mar 17, 2024
Re: Engine swap
yeah, starting from finding an ECU that works on D16 that still works with the new to 7th gen cars immobilizer, chassis, etc. Wiring will need to be all new. dizzy to coilpacks, etc, etc.
And then hitting a wall in licensing the car.
not worth doing a 6th gen engine into a newer chassis.
mega_stihl
May 1, 2023 08:13 AM
tundranugis
Engine Swaps
Feb 3, 2021 01:45 PM
DeeRod
Sep 28, 2016 09:15 PM
Clopez95ex
Dec 15, 2010 09:41 PM
steve93civichb
Aug 8, 2010 10:57 PM
