New dyno inside
Old Apr 6, 2007
  #61
Kevbotron's Avatar
I like my commute
Re: New dyno inside
Originally Posted by TransformedBG
K cup's are actually a lot smaller than that..
OK I'm done now
Old Apr 6, 2007
  #62
andyman97's Avatar
Turbo Guru
Re: New dyno inside
Lol, them would be some big ole tittays!
Driveability is perfect. No hesitation anywhere. Cruising afr's are around 14.5:1.
Old Apr 6, 2007
  #63
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Re: New dyno inside
what about the TQ steer!
Old Apr 6, 2007
  #64
andyman97's Avatar
Turbo Guru
Re: New dyno inside
Haha, that's inevitable.
Old Apr 6, 2007
  #65
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Re: New dyno inside
yo servion. if you are the servion i been hearing about in vegas how much can you tune my ride for. d17 emanage tune. PM me!
Old Apr 6, 2007
  #66
andyman97's Avatar
Turbo Guru
Re: New dyno inside
I'm sure its him. He tuned kelly's z6 to like 440 whp. You're best off emailing him at servion@hondaracingcrew.com
Old Apr 9, 2007
  #67
04civicdx's Avatar
04civicdx is an unknown quantity at this point
Re: New dyno inside
nice numbers u still got stock sleves ?
Old Apr 9, 2007
  #68
andyman97's Avatar
Turbo Guru
Re: New dyno inside
Yes I do, over 9k miles now.
Old Apr 9, 2007
  #69
ArjoonKumar's Avatar
ArjoonKumar will become famous soon enough
Re: New dyno inside
Only 9k...do u have another car or do u walk lol? How bad is ur TQ steer?
Old Apr 10, 2007
  #70
andyman97's Avatar
Turbo Guru
Re: New dyno inside
No, I only built the motor and had it finished around June-July, hasn't even been a full year.
Old Aug 15, 2007
  #71
7thgen.nick's Avatar
7thgen.nick has a spectacular aura about7thgen.nick has a spectacular aura about
Re: New dyno inside
nice numbers, is it still running well?
Old Aug 15, 2007
  #72
DsevenEm2's Avatar
This is Myspace
Re: New dyno inside
yea hows this beast keepin up andyman?? any problems? any more plans??
bump for update!
Old Aug 16, 2007
  #73
andyman97's Avatar
Turbo Guru
Re: New dyno inside
About 4 months ago, I spun out one of my rod bearings and trashed the crank. It was my fault, I had a pretty bad oil leak for a few months and neglected it so running low on oil finally spun one of my rod bearings out. I pulled the main girdle off and then the rod bearing caps to check and see where it spun out and if I trashed the crank or not and sure enough, on the #1 rod, there was metal to metal contact so that rod and the crank were trashed. The block and the pistons and other 3 rods were completely unharmed. I attribute it to my own laziness.
Shortly after that happened, I swapped my head onto a bone stock lx block and had been running 12 psi (about 260-ish whp) with a rev limit at 7k rpm. About a month ago, I bumped the boost back up to about 15 psi (300-ish whp) and raised the rev limiter to about 7400. Its' running very nicely and smooth. I don't have any issues with it and I haven't had a single check engine light since I've installed and tuned kpro.
As far as new plans, there are some things that need to be done before I go for more power. I need to work on suspension badly, I'm still on lowering springs and stock struts, lol. And there's alot of other maintenance I need to do. I have a lightweight flywheel and new clutch that are ready to go in. I'm going to pick up another spare block and build it again. My fuel system is finally at a point where its been extremely consistant. I need to pick up oil and fuel pressure gauges. I need to finish the wiring for my oem honda wideband, I'd like to get some nice sparco seats, and I need a new radiator support welded in and I want to pick up a cf front lip and hood to match my cf trunk. Just lots of things that cost lots of money.
The engine is in a place where its running very well and is extremely reliable, so I figure that I should take advantage and take care of everything else I want/need to take care of before I go messing with it anymore. Once I get everything else done, I'll start looking into a gt bb turbo upgrade, new turbo manifold, bigger fmic and some other power adders to get it over 450 whp on boost alone with race fuel. Its a long term goal and isn't something I plan to have done in the next 2 months, just whenever I get around to it.
Old Aug 16, 2007
  #74
Re: New dyno inside
Yeah sucked about the spun barring but oh well.. Take care of the other crap and you will be happy! Its well worth it in the end.
Old Aug 16, 2007
  #75
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
Re: New dyno inside
so...if that dyno was SAE corrected instead of STD what would your numbers be then?
Old Aug 16, 2007
  #76
Mr_Plenty's Avatar
Re: New dyno inside
Since its STD then i suppose you really dont have 374
Old Aug 16, 2007
  #77
andyman97's Avatar
Turbo Guru
Re: New dyno inside
The SAE correction factor came to 365.
Old Aug 16, 2007
  #78
robbclark1's Avatar
Retired suspension supermod.
Re: New dyno inside
cough...shocks...cough...brakes...cough...clutch fluid
Old Aug 16, 2007
  #79
andyman97's Avatar
Turbo Guru
Re: New dyno inside
^You know what I'm talking about. When do you want to help me do this?
Old Aug 17, 2007
  #80
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Re: New dyno inside
185 miles for half a tank!? Geez, I only get like 160-175 and my car is stock. Maybe I need a turbo...
Old Mar 31, 2008
  #81
carter's Avatar
carter is an unknown quantity at this point
Re: New dyno inside
This just goes to shut up my friends with the new 08 Type S TL. Who think Civic cant get up there. If your ever in Toronto up in Canada loll PM me ill give them a little run around. Man I would honestly lovee to in about a year to turn the 04 DX into a beast of sort. I dont want 300 plus but i'd love to hit 300whp.
So your FUel Economoy improved waow thats great a bonus to get my dad to chip a little money in :P
If you drive it to its "potential" does it wear down the car alot faster and what things do you do to maintain it??
Old Mar 31, 2008
  #82
andyman97's Avatar
Turbo Guru
Re: New dyno inside
There's really no additional maintenance. I mean, **** breaks, you fix it. If you beat the hell out of it, stuff will break more frequently than not.
I attribute the economy to kpro and the tune, honestly. If you can run a factory honda wideband in closed loop, you're golden.
If you liked this, I have something really special coming very soon
Old Mar 31, 2008
  #83
rick1574's Avatar
rick1574 will become famous soon enough
Re: New dyno inside
have you gone to the track with it recently?
Old Apr 1, 2008
  #84
andyman97's Avatar
Turbo Guru
Re: New dyno inside
Not yet. Sometime this spring. Just installed new injectors about a month ago and I'm going to retune it this coming Saturday. Going to try to get some vids.
Old Apr 2, 2008
  #85
rick1574's Avatar
Re: New dyno inside
how much hp did you have when you ran 13.8?
how fast are you hoping to run now?
Old Apr 2, 2008
  #86
andyman97's Avatar
Turbo Guru
Re: New dyno inside
It was the 250-260 whp range. I anticipate mid-high 11's.
Saratoga
26
Oct 2, 2015 09:05 PM
Islesfan
Sep 29, 2015 03:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
Elciteeve
Sep 28, 2015 12:40 PM
Bruce2
Sep 27, 2015 08:45 PM
