Kennykid2002's Build Thread
Old Jan 26, 2013
  #241
NAcaRice's Avatar
Low `n` Slow
NAcaRice is an unknown quantity at this point
Re: Kennykid2002's Build Thread
BOOYAAH
Old Jan 26, 2013
  #242
Kennykid2002's Avatar
Kenny the Ricer
Originally Posted by NAcaRice
BOOYAAH
Boo
Yeah lulz
Painted my VTEC Solonoid.
Old Jan 27, 2013
  #243
Tragedy's Avatar
skate or die
Boo
Yeah lulz
You're in my head. Been thinking about painting mine since the covers sold are too big. Did you use engine enamel paint? It looks nice.
Old Jan 27, 2013
  #244
Kenny the Ricer
Nope,
Just used the same Rustoleum high temp I've been using.
Engine enamel is high gloss, and that's not what I wanted.
Old Jan 27, 2013
  #245
fusion158's Avatar
fusion158 is an unknown quantity at this point
Just spend the last hour reading through this thread and very nice job Can't wait to see what you do next.
Old Jan 28, 2013
  #246
s4boost's Avatar
s4boost should not be trusted
looking good!
Old Jan 28, 2013
  #247
Kenny the Ricer
Thank you =]
Originally Posted by s4boost
looking good!
Thank you =]
Old Mar 9, 2013
  #248
Kenny the Ricer
Sorry for the lack of updates folks.
Installed the Megan test pipe, and since then been having a slew of problems.
One of which, is a dead alternator.
Car's been sitting in my garage this weekend.
Speedo and odo dead after alt cut off.
Old Mar 10, 2013
  #249
sl33pyriceboi's Avatar
#Becausetestpipe
Old Mar 10, 2013
  #250
krudmuphin's Avatar
I don't even know what that does.
Is it a fancy pipe that you smoke before taking a test that helps you get better grades?
Old Mar 10, 2013
  #251
Tragedy's Avatar
skate or die
Nice Brings back fond memories!
Got one of those and it needed a o2 simulator. Kinda pita, but it changed the sound and response of the exhaust.
Old Mar 10, 2013
  #252
Kenny the Ricer
Nope, it's basically a straight pipe that bypasses the cat.
It's called a test pipe because it's for "testing" purposes only, offroad use.
Not road legal.
It has nothing to do with passing emissions.
And you'll never pass any emissions with a test pipe
Old Mar 11, 2013
  #253
Tragedy's Avatar
skate or die
Unless you use an O2 simulator.. lol
Old Mar 11, 2013
  #254
Kenny the Ricer
No, you won't pass emissions with test pipes period.
Lol
O2 sim is to trick your engine into not throwing out a CEL.
Old Mar 11, 2013
  #255
Tragedy's Avatar
skate or die
Aside from the issues, did you like how it was running?
Old Mar 11, 2013
  #256
Kenny the Ricer
Love the sound, but the vic is being a pain in the *** recently.
Old Mar 21, 2013
  #257
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Tragedy has a good point. At some places, if your car has OBD2 they will just hook up a scan tool and see if you're throwing any codes along with a possible visual inspection. They do this to make the process quicker. The average driver is not smart enough to disable their check engine light
Old Mar 21, 2013
  #258
lowlife9's Avatar
dam i wish i could just pull parts off nice and clean like that and not have to use cans of PB blaster and replace rusted bolts. must be nice
Old Mar 21, 2013
  #259
Kenny the Ricer
Autozone no longer checks it.
I went to Midas, and their diagnostic guy wasn't in.
Got it fixed, alt fuse under dash blew when alt blew.
Got it replaced, everything's working good now.
Stock kitty back on for now, CEL is gone.
Lol, it is nice.
Just one of the perks of living in California.
Old Mar 31, 2013
  #260
Kenny the Ricer
Stock kitty sucks ***.
Test pipe going back on.
Old Apr 29, 2013
  #261
Kenny the Ricer
Got some work done over the weekend.
Not sure if you can see, but my black trims are faded to hell.
So I decided to plasti-dip them.
After:
Liked the look of it, so decided to do my window trim as well.
Here it is up close
Final result:
Looks good IMO.
Better than faded trim pieces.
Old Apr 29, 2013
  #262
krudmuphin's Avatar
looks good!
I just wipe them occasionally with armorall protectant and they stay black for a couple months.
Old Apr 29, 2013
  #263
Kenny the Ricer
Thanks, mine are way too faded to restore.
Anyways, something else I got done.
Rerouted both my cruise control and throttle cables.
So much nicer without them hanging about.
File Type: jpg
Old Apr 30, 2013
  #264
GolNat's Avatar
Prelude Owner
Clean looking engine! I didnt even think you could reroute the throttle and cruise cables.
The whole car is looking good! Like the painted trim. Was thinking of doing mine with plasti dip also. Think ill move that up on the priority list looks a lot better!
Old Apr 30, 2013
  #265
Kenny the Ricer
Forgot to mention,
Also painted my dipstick to match with Tragedy
Thanks man,
I didn't know I could too, till I tried it.
The throttle cable is such a stupid concept.
It goes from the middle of the firewall, all the way to the right strut, up over the intake and engine, then back down to the middle where the ITB is.
One thing I forgot to do, when I had cruise control throttle cable off, was to take off the cruise control and paint it.
Anyways, time to replace both my battery terminals.
Also, update on the plastidip.
Seems to be holding up well, even during wash.
It's a bit sticky and tacky first couple of days when it's still curing, but afterwards, it's smooth and durable.
When it gets soapy, my wash mitt just glides over, doesn't rub it off as I expect it to.
One thing, don't rub/mess with the dip when it's still curing, one mistake I learned :P
Old May 1, 2013
  #266
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Nice, Plasti dip is a great product for making things look good again.
Old May 22, 2013
  #267
Kenny the Ricer
Sprayed a little of this:
and it took out some of this:
Old May 22, 2013
  #268
GolNat's Avatar
Prelude Owner
Lol, where the hell was all that? Looks like speaker wire.
Old May 22, 2013
  #269
look like ricewire
Old May 23, 2013
  #270
Kenny the Ricer
Exactly what it was.
I used spare speaker wire to hook up some LEDs.
Took em all off now.
