View Poll Results: Who has had problems with there car?
Have never had any problems. Just done the normal maintenence ( oil change, brakes, etc. ).
45.66%
Have had a few problems here and there, but nothing major.
35.35%
Have had major problems with my car ( tranny, engine, etc. ).
16.16%
Have had severe car problems ( Items have been replaced more then once ).
2.83%
Voters: 495. You may not vote on this poll
Everyone Respond: Who has Had problems with there car and who hasnt had problems!!!
Old Mar 31, 2006
  #121
eddiechaps's Avatar
i love my morreale
i've had minro problems liek tires & stuff. nothing drastic.
Old Sep 18, 2006
  #122
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
It Has Been Perfect For 90k Miles.
2001 Lx Coupe M/T
Old Sep 18, 2006
  #123
Jeff's Avatar
Jeff is an unknown quantity at this point
3 trannys,
3 clutches
5 master cylinders
3 slave clyinders
one oil pan
1 alt
1 power steering pump
4 struts
1 gauge cluster
crank shaft bearings,
rod bearings.
piston rings
2 oil pickups
2 oil pumps
headlight switch x2
Naw i havnt had to many problems, I only have 40,000 miles on it aswell.
lol
Old Sep 18, 2006
  #124
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Keep it going...
01 EX Coupe MT with 90,000 miles
Only problem is flaking clearcoat all around the car (9 spots).
Regular maintenance, good gas mileage, very reliable.
Clutch is starting to slip a little, but not bad for the way it's driven!
Old Sep 18, 2006
  #125
2k1_sedan's Avatar
2k1_sedan is an unknown quantity at this point
01 Civic 67k miles, some emissions issue in the first year, covered under warranty. Nothing else.....but normal wear and tear.
I wonder if where your car was made affects this at all? Mine came from Japan.
Old Sep 18, 2006
  #126
red05's Avatar
red05 is an unknown quantity at this point
2005 vp civic coupe, 16,000 miles and a few problems. The roof had to be repainted because of flaking clear coat, the clutch has been fixed twice, and the passenger door panel has been replace because it cracked.
Old Sep 18, 2006
  #127
Hurts2bStock's Avatar
Shinier than yours, meatbag
My trans needed full rebuild right after I bought my car, but now the car runs fine...
BUT, I do have a messed up rheostat in the gas gauge ...........some times it says I'm on empty and I put 10 bucks of gas in and then I'm almost full.
At least it says I have less gas than more ...
Hey could the gas guage be from poor grounding?
Old Sep 18, 2006
  #128
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
01 MT 78K and counting. Other than a front end collision where I had to replace the radiator, no mechanical problems really. I still get some idle problems where it will drop unexpectedly but tranny is awesome. Paint is shitty though but overall, a reliable DD. Its a keeper!
Old Sep 18, 2006
  #129
50k miles
slipping auto trans
alternator replaced at 20k
a/c recharge
warped rotors
blown headgasket (my fault)
dimples in body
and lots of little small things i was able to diy fix, mostly the tsb's
Old Sep 19, 2006
  #130
orion_squall's Avatar
update from post of 5 months ago:
Now 110000Km
No problem at all yet, nothing replaced on the car yet, not even brake.
Old Sep 19, 2006
  #131
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
At 33k miles my countershaft bearing decided it wanted out. It was covered under warranty. It decided again at 34k miles it still wanted out, but was gonna take the main shaft with it. Again, covered under warranty. The countershaft was nationally held for 6 weeks... you couldn't order it. Thank god I worked for the Honda dealership doing the repair - and they gave me a AWD 5spd Element for that time period until my car worked again.
Never payed a cent - and no problems since.
Old Sep 19, 2006
  #132
CdKoInU's Avatar
CdKoInU is an unknown quantity at this point
before my k20a swap
around 84,000miles
0 problems whatsoever
just replaced tires a couple of times (due to rim replacement)
normal wear on the paint
excellent gas mileage
2002 LX coupe
man I love it
Old Sep 19, 2006
  #133
lxcivic2k1's Avatar
01 Lx M/T with 50k miles, had it since 31k.
No problems yet that I haven't caused...only 1 accident which was easily fixed at not the cars fault and then hail (also fixed).
Might have a front joint going bad but not sure yet.
Old Sep 19, 2006
  #134
lumpy007's Avatar
lumpy007 is an unknown quantity at this point
i got an 01 ex coupe 47000 miles and the only problem i have had was the battery died on me a coup;e of weeks ago!!
Old Sep 19, 2006
  #135
IMAhybrid's Avatar
IMAhybrid is an unknown quantity at this point
Fuel door cable was replaced for free, under warranty. Besides that, just a a dent in the hood. I've had the car a little over a year now, it's an 05 with 23k.
Old Sep 19, 2006
  #136
RHCP0801's Avatar
27,000 miles on the car...almost 3 years old and no problems at all yet(knock on wood)
Old Sep 24, 2006
  #137
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
67k.. no problems at all that were not my fault... with one exception...
about a month after i got my car a spider got into my cluster and built a web over my gas gauge... i knew nothing about my car other than that i finally had a car that cost more than $400... stealership charged me $80 to fix it... they left fingerprints all over the inside of the cluster... i then took it apart and fixed it myself...
Old Oct 7, 2006
  #138
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
04 em2
driven in hawaii 23875miles total
damaged drivers side seat rail (replaced under warranty)
thats about it
Old Oct 7, 2006
  #139
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
88000 miles and the ECU had to be replaced, under warranty, it was a pain in the *** but it would have been $850.
that's about it!
Old Oct 7, 2006
  #140
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
sporatic engine noise, sounds like two belts rubbing together...think its due to the timing belt tensioner hitting the casing, there has been an issue, and there is suppose to be a new tensioner available, had to stop short, abs sensor failed, wheels locked up, slammed into the back of a accord..that was fun, and trunk is leaking water, has been to honda twice, both times thought to be fixed, but there is still leaks.
Old Dec 2, 2006
  #141
CraigW's Avatar
My 05 sedan is up to almost at 40k miles, 3 months from being 2 years old. My average is around 450 miles per week. It gets a workout.
The RE92 Potenza tires are VERY noisy but have reached the rated 40k. Rotated every 5k. Replacing with Michelin Harmony models soon.
The problems that I had repaired under warranty coverage were, Drivers seat rocking / Oil leak. They replaced the oil pan gasket and some washers / Slight buildup at power steering line connections on rack. They just need to be tightened / Passenger front strut leaking. (at first they were only going to replace 1 but changed both fronts) The rear struts have an area on the lower section outer sides that has the paint worn off. Dealer said they are o.k.
I use a 5k mile interval for oil changes (Castrol 5w20, OEM filters) Transmission drain and re-fill at 25k miles.
I have traded back and forth between Corollas and Civics for years (both are great) I have never in over 20+ years of owning Japanese models been left stranded or failed to start without an easy fix. In all that time I have never done any major repairs only maintenance and basic repairs.
Drive on !!
Old Dec 2, 2006
  #142
drunkenmagnum's Avatar
blew the HEAD GASKET but that was the turbos fault and not hondas so i dont know how to answer that.
Old Dec 2, 2006
  #143
CenZ's Avatar
PWIT
blown struts but thats my springs fault. and now my clutch bearing is going. but honda wont fix it cause im lowered
Old Dec 4, 2006
  #144
civ_nate's Avatar
civ_nate is an unknown quantity at this point
had my tranny replaced, then rebuilt, and my altnator is toast
Old Dec 4, 2006
  #145
sugisan's Avatar
sugisan is an unknown quantity at this point
05 ex 16k. no problems at all
Old Dec 11, 2006
  #146
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
RIP 3rd gear synchros and driver's side door lock at 60k miles; all replaced under extended warranty.
Old Dec 11, 2006
  #147
estebomb_ftw's Avatar
05 Ex here. Just passed the 18k mark last night and running strong.
Old Dec 12, 2006
  #148
D5cIvIc's Avatar
75K and only have my driver side lock actuator going out and also my rear window defroster no longer works for some reason...
Old Dec 12, 2006
  #149
sl33pyriceboi's Avatar
everyting fine......
my VSS craped out on me. replaced it, everything fine =]
Old Dec 18, 2006
  #150
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
no problems with mine so far
