View Poll Results: Who has had problems with there car?
Have never had any problems. Just done the normal maintenence ( oil change, brakes, etc. ).
45.66%
Voters: 495. You may not vote on this poll
Everyone Respond: Who has Had problems with there car and who hasnt had problems!!!
bought mine 2 yrs ago, no performance mods, only ICE, rims + lip kit. So far its dead b/c Wilma threw a ancient *** magnolia tree on it totalling the car. Right now Im driving my dads camry brought back the ridgeline.
05 Ex Se 12,000 miles. No major problems yet, except for my driver's side window, it rattles when I have it down and hit bumps even at slow speeds. oh yeah and little rattles here and there, but that's probably because the system loosened everything up in the car...other than that no probs here
Have 05 Si (Canadian) 4300 Kms (2700 Miles) Have this rattle in the back window somewhere and when I hit a puddle i get water inside the car around the front passenger side door.
bought mine last june (01 Lx Coupe 43xxx now) no problems besides rattles thanx to the subs and my stop light(spoiler light) has a bad LED on the end so it flashes. And bad battery.
But no problems in the 12000miles i put on it *knocks on wood*
03 si coupe (CND) 103000 kms
rocking seat.
clutch master cyl. replaced - warr.
head gasket went at 56000km thye ried replacing everything else first...thermostat...ect.
headgasket changed under warr.
then the oil consumption started....was ongoing 1.5L per week.
the changed the head at 66000km - warr.
still had oil trouble they finally got the go ahead to change the short block at Xmas so basically new engine now.
the timinig belt tensioner went at 75000km too they changed timing belt, tensioner, and water pump. - warr.
I think that is it.
rocking seat.
I think that is it.
problematic 7th gen
yea, my cv axle has broken, my trunk latch has broken, my clutch is starting to slip, my tranny grinds from 2nd to 3rd, it grinds going into reverse, my drivers seat rocks back and forth, my suspension squeaks, my passenger side window regulator is broken, i sent a letter to american honda, and my car is currently in honda shop getin looked at,its an 02 with 42K on it
2k2 civic ex auto, 45k miles, slipping tranny, broken alternator (lasted 2 years), bad tps sensor, headgasket, radiator cap, warped rotors, broken swaybar, windows roll down too slowly, broken seatbelt buckle, faulty fuel sender, defective sun visor, broken mirror switch, driver seat rock, suspension creaking and clunking, .
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
88+K miles and no real problems in the engine bay...driver side automatic window does not always go down somtimes but that does not happen so often anymore
but other than that, my baby is working just fine!
but other than that, my baby is working just fine! Joined: Sep 2002
i changed fluid at 18k and again at 30k and again at 40k. have trans oil cooler installed as well. you can't prevent a factory defect.
I hope I offend you... Get mad
Everything was fine untill 84,000 miles and boom hole in engine. Then because i had a header and intake my warranty was'nt covered. No problems other than that. Just dissapointed that honda did me wrong and ive been worshiping them since i was 16.
squeaky clutch still bugs me... then again i bump start all the time these days lol 38000 km and counting
and sometimes i overrev on a rev match...
2004 civic coupe 5spd DX with AC best tank (5.4L/100km or 43 mpg all city driving)
2002 EX Auto Coupe Rocking Seat Replaced Bushings By Honda Under Warranty. 54,XXX. Waiting For Auto To Die So I Can Make It Manual! LoL JK Want A Tranny Conversion Though.
the only problem that i had was my front tire keeped going balled in a year, latter i noticed my tire ate threw the wheelwell some how. o and i needed my seat replaced after like only 5,000 miles something happend and it came off some brackets or something.
other then that all the other problems i have had where due to putting a turbo on my car.
