ECU Fried 7th Gen cars have a Chronic issue - alternator bolts get loose and the loss of grounding will eventually fry the ECU
Is this an ECU issue or something else?
Old Aug 9, 2021
ajee.martin13's Avatar
ajee.martin13 is an unknown quantity at this point
I want to tell you everything that was going on to maybe help diagnose the issue.
Last Thursday night it wouldn't start. Got a jump and it started with no issue and I let it run for about 20 minutes before turning it off. Friday morning it wouldn't start and I took the batter to autozone to get checked and charged. They said the battery was good and tested the alternator and said it was bad. Then I replaced the alternator. Car started with no issue. Then Sunday at noon I tried to start my car and it wouldn't start. So got it jumped and took it to Firestone and they said my battery isn't keeping a charge so they replaced it. And Monday I filled my tank. Tuesday afternoon I tried to start it and it had a rough start but it did and I backed up and put it in drive and it stopped. So I tried to jump the battery and wouldn't work and the battery light came on this time. So I checked the alternator belt and the connector but the connector came off with out me having to press the tab in. I’m not sure what is going on. My mechanic is saying it’s the ecu but from everything I’ve looked up and read sounds like the main relay. Please help.
Old Aug 10, 2021
Re: Is this an ECU issue or something else?
what do you mean connector?
also, check if the alternator bolts loose. That tends to kill ECU's with voltage fluctuations
OE alternator is recommended, many stories of remanufactured/aftermarket not working well
Old Aug 10, 2021
what I mean by connector is the plug that gets plugged into the alternator and also splits to the battery I believe. Has a ring that goes over a bolt on the alternator and nut screwed in to keep in place.
Old Aug 10, 2021
that could cause voltage fluctuations...
Before going into the ECU, try to get everything checked.
Lots of alternators being returned because they don't work well, BTW...
Old Aug 10, 2021
an ad for alternator just popped up in our marketplace, BTW.
and it is in TX.
Old Aug 27, 2021
So sent in my ecu to ModuleExperts, and they told me the computer chip is completely fried and will have to send me a whole new refurbished one to replace it. I just hope that is actually all that’s wrong with my car. Still waiting for the part to be sent to me.
Old Aug 27, 2021
after replacement, you will need program keys to it
Old Oct 7, 2021
Ok so a month later no further progress. Ended up taking it to a Honda dealership and took them 2 weeks to tell me it was my fuel pump….well it wasn’t my fuel pump. They told me that the reason they said that was because I wasn’t getting compression with my other one, around 10 psi. So they said it started then stalled and died and couldn’t start it again but now holding the proper compression, 41-44 psi. My personal mechanic said the pump was fine and he thinks its an electrical issue, prior to me taking to the dealership for diagnostics. Now they tested it and saying the car is out of timing. So they recommend that i get a new engine. Are any of these signs of a timing belt jumping? And if anyone in Texas would like to help me out, please let me know. Not in a position to buy a new car. Also don’t want to buy an engine and that’s not the issue.
Old Oct 7, 2021
Colin42's Avatar
Not hard to check the mechanical timing...
Old Oct 7, 2021
I understand that. However, I was referring to the symptoms I mentioned in my first comment. Currently do not have my car to check at the moment.
Old Oct 7, 2021
FRSam's Avatar
Click Here
Has the check engine light been on at any point? If timing was off, it'd be in limp mode and throw a code.
What's the mileage? What mileage did you get the car?
Old Oct 7, 2021
When my mechanic looked at it only code was the cat low efficiency code, which I’ve had prior to all this. Since the ecm was replaced, I haven’t been told anything about any codes. I got the car at 110k, it’s at 160k
Old Oct 7, 2021
FRSam's Avatar
Click Here
You got it right around when the timing belt should have been done. Did you ever do it/was there ever proof of it being done?
Old Oct 7, 2021
ask them to check if cat is plugged?
Old Oct 7, 2021
I was told all of that was done, but I didn’t have it checked again in the 6 years I’ve had the car.
Old Oct 7, 2021
it’s a new cat I had put on last year Halloween. Check engine light went off for like 5 miles and came back and haven’t been able to figure it out since then.
Old Oct 7, 2021
Colin42's Avatar
still p0420? Cheap aftermarket cat, Hondas are picky
Old Oct 7, 2021
then the o2 sensors. Or your dying ECU (replaced now)
Old Oct 7, 2021
02 sensors were replaced with cat. And ecu has been replaced.
Old Oct 7, 2021
Probably. I went where a friend recommended me to get one.
Old Oct 8, 2021
Colin42's Avatar
Put a defouler on the secondary o2, should go away
TheWiz
Electrical
Apr 21, 2020 07:16 PM
Coosterhuis
Engine start problems
Apr 9, 2016 01:59 AM
joshua.mills
Nov 16, 2014 10:05 AM
fusion158
Dec 1, 2012 06:25 PM
talon187
May 8, 2011 05:16 AM
