2002 Civic No OBD reading
I have a 2002 civic , I’m not really sure what trim it is but it has a 5 speed & the d17 vtec . Anyways since I bought the car it wont rev past like maybe 3000rpm , also nothing on the dash shows reading (temp gauge &tachometer) . I tried hooking up a obd2 scanner to it & im not getting any signal. I checked every fuse. I also took it to a shop & they couldn’t find a problem. It seems like this is a common problem but I can’t find an exact match for the issues that I’m having. I’m leaning towards it being a ecu, I just want to double check though before I buy one. Thanks for the help 🙏🏾
Re: 2002 Civic No OBD reading
check if the alternator bolts are loose
if yes, the ECU is fried (fairly common issue in these cars)
moved to the forum section with similar cases, start reading
jamie_0192
Apr 3, 2015 09:50 PM
patbonen
May 3, 2012 10:35 PM
metalworks
Aug 3, 2007 09:44 PM
bogdanf
Mar 29, 2007 01:51 AM
