Strut and Coil Spring replacement questions...
Old Dec 23, 2010
KingArthur's Avatar
KingArthur is an unknown quantity at this point
I bought a 01 Civic Ex with 179000 miles and all 4 struts are blown. The car has 18" wheels on it and with 4 people in the car the rear rub when it bounces.
My question is... Should I replace the springs along with the struts because I'm not sure how long the struts were blown and riding on the springs.
I would like to kept the stock height...nothing performance, so what would be your suggestions for what to put on it. Do they sell the strut and coil spring together? Who has the best price?
Old Dec 23, 2010
MindBomber's Avatar
Live for the Twisties
Re: Strut and Coil Spring replacement questions...
Springs don't wear out, just swap your current ones onto a new set of struts and you'll be fine.
Old Dec 23, 2010
KingArthur's Avatar
Thanks any brand recommended for stock height?
Old Dec 23, 2010
MindBomber's Avatar
Kyb GR-2 is a good strut for stock height, its basically an OEM equivalent.
Old Dec 23, 2010
sl33pyriceboi's Avatar
i would take tokico blues over KYB in a heart beat.
the blues have a bit better dampening and will hold its ground better than the KYBs......even for stock height.....and especially if u are going to carry 4 people in the car.
take a look at this thread:
https://www.civicforums.com/forums/4...yb-gr-2-a.html
Old Dec 23, 2010
lowlife9's Avatar
are you sure that you have stock springs on the car ???
Old Dec 23, 2010
TRIZ's Avatar
You might be able to find someone getting rid of an aftermarket suspension setup that's better and cheaper then a replacement oem setup.
Hint, check out my part out three (link in Sig)
Old Dec 27, 2010
not trying to beak your deal, but he is on 18" wheels, so he will need to keep the coilovers at full height
the stiffer springs might help, though
oneheadlight
Apr 29, 2015 11:30 PM
thesushiboy
Apr 12, 2015 02:54 AM
SugarRay
Dec 6, 2001 05:17 PM
deception420
Dec 6, 2001 02:31 PM
EvilTwin
Nov 8, 2001 12:17 PM
