Advice on replacement struts
Old Mar 22, 2005
drcivic's Avatar
drcivic is an unknown quantity at this point
I recently got my tires rotated and the tire shop said all four of my struts are leaking and will eventually need to be replaced and I've noticed that I've been getting that hollow knocking sound when going over bumps.
I would like to replace these myself to save a few bucks but I've been reading a lot of posts saying that some of the aftermarket stuff doesn't quite fit right and you have to cut stuff etc. I just want a good replacement strut cause obviously the stock ones suck and always leak (these are my second, first ones replaced under warranty). I have no intentions of lowering my vehicle or anything, I just want an easy to install strut that's good and won't leak. What are my options? TIA.
Old Mar 22, 2005
robbclark1's Avatar
Retired suspension supermod.
What year civic? Tokico's would be your best bet or just get some OEM ones.
Old Mar 22, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
If you can tell us what year your civic is.. we can tell you whether you will have problems installing certain aftermarket struts.
If you want your car to handle better.. I'd suggest getting a set of Tokico HP Blues. They arent too expensive and are a good replacement compared to the stock ones.
edit: damn u rob! u beat me to it hahah
Old Mar 22, 2005
drcivic's Avatar
2001 LX coupe.
Old Mar 22, 2005
robbclark1's Avatar
Tokico HP (aka blues) will do well. KYB GR-2s also are a good choice.
Old Mar 22, 2005
Nameless's Avatar
TURTLEonK
Originally Posted by drcivic
2001 LX coupe.
oh.. in that case u are pretty much open to any aftermarket struts.. its usually the 03+ that have to do a little custom work in order for the struts to go in.
Old Mar 22, 2005
jttegx's Avatar
OMNES AD UNUM
tokico blues (HP). best struts for the buck and great for OEM replacements.
KYB's are little more pricey i think, your call.
check out the shock/damper faq
Old Mar 22, 2005
drcivic's Avatar
So are these Tokico HP a lot better than say Monroe OEM struts? Also, where is the best place to buy these in Canada and what kinda prices am I looking at? Thanks.
Old Mar 22, 2005
flotsamm's Avatar
I dont think Monroe makes replacements yet for our cars.
Old Mar 22, 2005
SmiteSwift's Avatar
SmiteSwift is an unknown quantity at this point
Koni's are little pricier but I am very happy with them. Plus they are repairable if anything goes wrong, and any shop should know how to fix them.
I suppose if I had a 01-02 I would have probably gone with the Tokico HP.
Old Mar 22, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
PM me and I will get you a price on them.
Old Mar 23, 2005
1955's Avatar
kyb gr 2 is what i have now and they are excellent replacement struts,i paid $89 at importpart.out handle the stock struts i must add.
Old Apr 12, 2005
draganjr's Avatar
draganjr is an unknown quantity at this point
Are the KYB GR-2 good with the Pro Kit?
Old Apr 12, 2005
Superman2004's Avatar
Superman2004 is an unknown quantity at this point
hey guys....can you just use tokico with your stock springs?? I mean, will they change your ride height any?
Old Apr 12, 2005
ojay's Avatar
ojay is on a distinguished road
yeah you can use tokico with stock springs, and it shouldn't adjust height.
Old Apr 12, 2005
thanks..but another quick question...what if you cut your bump stops?? If you leave the cut bump stops in the tokico`s and then put stock springs on...will that raise my rear to the stock height without problems? I could use the old control arm too...right?? Trying to convert my car pretty much back to stock....thanks I appreciate the help
Jigee
May 9, 2015 11:18 AM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
2001CivicEx2dr
Jan 6, 2002 02:07 AM
bluecoupe
Dec 19, 2001 10:08 PM
