Sponsored by:
Sponsored by: CARiD
Strut bar install
Old Jan 2, 2002
2001CivicEx2dr's Avatar
2001CivicEx2dr is an unknown quantity at this point
Strut bar install
I bought a Matrix front upper strut bar last month, but had to put off installing it because of an accident. It's not an expensive one ($30 on eBay) and there's no instructions for getting it in. I'm guessing that I just take off the 3 nuts on each side and sandwich it in. But the nuts don't want to come off[IMG]i/expressions/laugh2.gif[/IMG]... and I don't want to force them without knowing its not hurting my car. I tried this with a regular 9/16 wrench
any advice[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 2, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
Maybee you should grow some ***** and torque that sucker.....
Old Jan 2, 2002
Grey's Avatar
DIY King
[IMG]i/expressions/laugh2.gif[/IMG] Also, counter-clockwise is the way to unsrew things. In case you were doing it the other way. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 2, 2002
StealthBlack's Avatar
StealthBlack is an unknown quantity at this point
And shouldnt you be doing this with a 10mm wrench instead of a 9/16th ??
Old Jan 2, 2002
k well I was screwing it the right way, just not hard enough.... wanted to run it through the board before I risk any part of my 16k $$ machine[IMG]i/expressions/face-icon-small-cool.gif[/IMG] and I know that hondas are in metric but a standard set was all I could find and it didn't strip it
thanks guys
Old Jan 2, 2002
2k2civic's Avatar
Ya, 10mm...by the way - don't be afraid of giving it muscle, it's a bolt, it's meant to be tight. If it was something like an engine bolt, more to worry about, but with something like this, you can't really do it wrong (unless you've been living in a cave for the past 20 years.)
Old Jan 2, 2002
rac53041's Avatar
rac53041 is an unknown quantity at this point
its actually 14mm
Old Jan 3, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
drench the nut and bolt with some lubricant and use a pipe over your wrench for extra leverage.
Old Jan 3, 2002
Bartkat's Avatar
i think this one calls for a 97 inch pipe.
Seriously, those bolts and nuts ar plated and shouldn't be rusted or hard to break loose. It might take a little more pull than the standard wrench, but if the wrench doesn't fit well you really could strip the nut flats.
Old Jan 3, 2002
eXNBP's Avatar
eXNBP is an unknown quantity at this point
WD-40
Old Jan 3, 2002
Bartkat's Avatar
If you are going to do stuff to your car the best investment you can make is a nice set of metric wrenches. You can get a decent set of sockets and handles and combination wrenches for $50 or less. That will save you much grief someday for sure.
Old Jan 3, 2002
Micks2K1's Avatar
Micks2K1 is an unknown quantity at this point
ahh finally some good old fashion ripping a guy a new **** hole why cant we do this more often Im getting sick of this ***** shiit where we cant swear.
Old Jan 4, 2002
spoiledsteph
Guest
Posts: n/a
i got my tool set for $20 and it had all metric and standard wrenches and sockets. best 20 i ever spent!
Old Jan 4, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
<< ahh finally some good old fashion ripping a guy a new **** hole why cant we do this more often Im getting sick of this ***** shiit where we cant swear. >>
what the hell are you talking about?
Old Jan 4, 2002
2k2civic's Avatar
Question - can you use an impact wrench or would that not be a good idea?
Old Jan 5, 2002
2k2civic's Avatar
I don't know why everyone says those bolts are to tight. They're not tight at all - it actually kinda worried me, it took hardly any muscle to get that bolt off.
Old Jan 5, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
Ya, it's either 9/16" or 14mm.
Old Jan 6, 2002
mohawkboom's Avatar
Yup.. and when your done.. make sure you tighten back all 3 bolts to the reccomended 120 ft.lbs of torque each... Or.. tighten the living hell out of it.. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
bluecoupe
Nov 28, 2001 08:21 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
