Sunroof Drain Tubes Leaking
Old Sep 6, 2023
Moogie's Avatar
Moogie is an unknown quantity at this point
Hey gang. So I've had the same problem: water in the cabin (floor, both sides, front) from apparently "clogged drain tubes", on a 2022 sunroof that I absolutely NEVER use, after a big downpour,
I am flumoxxed as to why it's ok to let Honda get away with a mechanism that lets water inside the cabin when it is never even opened or used. There are several class action suits to other makes (VW, Volvo...) but I don't see Honday.
That being said, is there a way to PERMANENTLY SEAL THE DARN ROOF? I don't want it, I don't use it, so I'd be happy to have it sealed up and never allow "debris" into the tubes. Thanks!
Old Sep 6, 2023
BrotatoChip's Avatar
Super Moderator
Re: Sunroof Drain Tubes Leaking
Moving to your own thread in the proper section.
It's not feasible to have a perfectly sealed sliding window on the roof. So, the window seals the best it can then the catch basin underneath takes care of the small amount that gets through. It's been this way for like 30 years. Roof window drains really should never clog. My '02 with 325k miles has never had issues. You need to check what the issue is or take it in for warranty.
Old Sep 6, 2023
Colin42's Avatar
You have warranty for a reason....
You can always sell it and buy a car without a sunroof.
Old Sep 6, 2023
Moogie's Avatar
I completely agree they SHOULD never clog…
therein lies the problem.
the dealership claims “the drains were full of debris, I need to clean there regularly, so it’s maintenance and therefore not under warranty”.
I say BS, it’s a design flaw, since the sunroof is never used and never opened, how is “debris” getting in there and where does it say we need to open it to clean there regularly, and why the heck do clogged drains then leak INTO the cabin instead of outside????
but I’m in a catch-22, Honda says speak to the dealer, the dealer says case closed.
there have been class action suits against VW and Volvo and even BMW for the same problem, but not Honda it seems. I’d join one if there was.
so really what I prefer is for the sunroof to simply go away. I’d love to seal it up completely to become “debris-proof” but haven’t heard of any method yet.
Old Sep 6, 2023
Moogie's Avatar
they consider this a maintenance issue and refuse it as warranty. I’d sure like to know how to fight that.
Old Sep 7, 2023
123Krash's Avatar
123Krash is an unknown quantity at this point
PERMANENTLY SEAL THE DARN ROOF..
May not look the best but.. Flex Seal should do the trick., and it may not be easily reversible.
Flex Seal
https://www.youtube.com/watch?v=IOTk5YXHGRQ
Old Sep 7, 2023
Moogie's Avatar
Flex Seal
thanks, yes, that’s the kind of thing I’m wondering about. Or even soldering it shut 😉.
. hoping to hear actual experience, but I may be shooting into the wind.
Old Sep 9, 2023
123Krash's Avatar
What year is your car.. the '08 and '12 have a glass sunroof with rubber gasket all around, no way to solder that.
If you have a car with full metal sun roof. it would be possible to sand it to bare metal and solder or weld, but the heat may/will disform the metal unless careful.. I woudl think you would jaut ise silicone caulking and not have to destroy the paint to seal iit.
Old Sep 9, 2023
Originally Posted by 123krash
what year is your car.. The '08 and '12 have a glass sunroof with rubber gasket all around, no way to solder that.
If you have a car with full metal sun roof. It would be possible to sand it to bare metal and solder or weld, but the heat may/will disform the metal unless careful.. I woudl think you would jaut ise silicone caulking and not have to destroy the paint to seal iit.
2022
Old Sep 10, 2023
Moogie's Avatar
thanks. Glass and rubber here.
I siliconed a windshield 30 years ago, ended up with more rust under it. Sigh.
Nohippychicks
Exterior
Sep 4, 2020 10:33 AM
RHewitt
Exterior
15
May 18, 2019 06:33 AM
had2010
Feb 5, 2011 09:24 PM
jmontoya21
Sep 29, 2009 06:48 PM
NukeSilo
Apr 29, 2002 04:27 AM
