wet floor carpet after heavy georgia rains any suggestions on how to repair this?
im in the middle of a system prep for audio install and wanted to put the amps under the seats but it turns out water is leaking in from somewhere,and now the floor carpet is wet, anybody has any suggestions or previous experience with this? any tips will be greatly appreciated
2001 sedan
2001 sedan
Re: wet floor carpet after heavy georgia rains any suggestions on how to repair this?
use a hose to see where water comes in from. either a door seal or window seal. or moonroof drain tubes if you have EX civic. as for the carpet, leave the car in the sun for a few days with windows open.
i have the same problem mine is coming from above the dead pedal
i had my window replaced from honda on a recal years ago and i had a side plug come out also.. no time to check but you can look at those areas
usajags84
15
Aug 19, 2015 03:12 AM
AngeloS
Jul 16, 2015 11:00 PM
2HondaCivics
Jun 19, 2015 12:06 PM
ashlava71
May 16, 2015 12:54 PM
