Passenger Window not rolling up
Old Jun 18, 2015
2HondaCivics's Avatar
2HondaCivics is an unknown quantity at this point
Hey yall,
My 2003 Honda Civic EX passenger window will not roll up. What I'm guessing it's the left side switch because I used the right side passenger switch to roll it part down. I did not want to continue rolling it down because i park on the streets and in case it rains. Any suggestions? My master switch rolls up the driver side window up and down just fine. Just need to figure out which switch i need to replace.. And i'm hoping it's just the switch.
Any suggestions or advice would be great!
Thanks,
Mr. 2Civics is always clueless
Old Jun 18, 2015
GolNat's Avatar
Prelude Owner
Re: Passenger Window not rolling up
Could be the switch or a bad wire in the door crease. Do you have a multimeter?
Old Jun 18, 2015
Nope.. No multiMeter.. I'm hoping it may be the switch and if it is, not sure which one I should replace
Old Jun 19, 2015
CraigW's Avatar
The voltage from the master switch runs straight through the at rest single window switches at each door. Then to the motor.
You can get a 12V test light for a few dollars to see if voltage is coming from master.
I love the super sharp, insulation piercing tips they have.
Schematics are on this site.
Blazz
Aug 30, 2015 11:07 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
Burgeogull
Aug 14, 2015 05:12 PM
mrwhos
Aug 11, 2015 02:03 AM
jpandjf
Aug 3, 2015 05:02 PM
