Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
The Parasitic draw
Old Nov 29, 2021
Supergoochwarme's Avatar
Supergoochwarme is an unknown quantity at this point
Question The Parasitic draw
Working on son's 2009 civic hybrid and we've replaced the 12V battery 4 times in 2 years and jumped it more than I can remember, yesterday I pulled every fuse from inside and out trying to find the source of parasitic draw. I was between 70-85mA and it never changed when I started systematically pulling fuses. I ended up pulling almost all the cables and connectors inside on the fuse panel but never found the draw. I have seen where folks have issue with the windows/door locks so I'll try that this afternoon, has anyone had issue where they pull everything and still have a draw? Any ideas of what could still be powered 12v and key not on? 1. Doors/Windows. 2. Radio/Navigation? 3. Bluetooth connection?
I pulled aftermarket remote starter and everything I could think of, just not finding the right leak to fix.
Set car with windows down and doors closed - let sit 20min
Draw @ 75mA and started pulling fuses in engine bay....nothing
Disconnected AC compressor and pulled relays...nothing
Pulled fuses inside car and connecting cables to the panel...nothing.
At the end of my rope, as usual the Stealership couldn't 'replicate the issue' so I'm on my own here and looking for ideas of 12v always on that could be stuck...thanks
Old Nov 29, 2021
Re: The Parasitic draw
not recharging?
Old Nov 29, 2021
It does recharge but the boy only drives 3-4 miles each day so I've had him run up and down the highway to help recharge. It goes through fits of dead battery and then fine for awhile, that's why I think it's something stuck that's always 'on' like door switches or something. I've checked the AC clutch and rear defroster (found via google as a problem) but that's not it.
Old Nov 30, 2021
BrotatoChip's Avatar
Super Moderator
75 mA draw doesn't sound crazy high. If it's intermittent like you said, maybe the draw jumps up sometimes.
Old Nov 30, 2021
I didn't think 70mA was high either but according to the interwebs and manuals anything above 50mA is a drawdown and could cause problems. I did some more work last night and systematically disconnect items and nothing seemed to drop down the amperage. Dropped the radio, auto start, even the main fuses from the battery to everything below it to no avail. It intermittently pissing me off....if anything I appreciate the forum to vent
Old Dec 1, 2021
Super Moderator
Does the car get driven regularly? Like once a week or more?
Old Dec 1, 2021
Every day, it wasn't but 3-4 miles so I told him to run around after work on the highway to help charge it. On weekends I made him run it for 15 minutes in morning/afternoon to keep it charged. We had a cold snap of -10 so I told him to run it when he gets the chance as it kills batteries at those temps.
I did have a window that appeared stuck (wouldn't move up or down) so after freeing it up I disconnected that connector in the door, this morning it started fine and the IMA battery indicator isn't jumping around as much and seems more steady. I hope to heck it was a stuck window trying to move up or down, but it doesn't make sense as that's not always 'powered on' and only operate when keyed on.
Old Dec 1, 2021
pull the grommet around the door hinges electrical wires and check if the wire insulation is not damaged. If yes, fix that
ATEM2144
Electrical
32
Oct 11, 2022 08:28 PM
potomacguy
Electrical
Sep 4, 2021 08:46 PM
Dustin Rust
Electrical
Nov 24, 2020 08:46 AM
archi
Electrical
Jan 27, 2019 03:31 PM
polocarter
15
Dec 4, 2016 11:35 PM
