Electrical Post information/questions/Issues about Electric parts here.
10 amp fuse issue
Old Jan 21, 2019
archi's Avatar
archi is an unknown quantity at this point
Arrow 10 amp fuse issue
My mechanic ran thorough tests as to why a new battery ( 3 in a row within 24 months) is draining after sitting for a day or two max. The alternator seems to be OK , ground is fine too, we found the drain coming from the 10 amp fuse in the under hood fuse box.
This fuse was removed, so now the sunroof,taillights radio are not working, as well as the door locks don't work without the ignition being on.
So can anyone tell me how should i proceed with this issue what should be done just to replace the fuse or it has other mechanical fix beforehand ?????? I have read a lot that Honda Civic'S are with default technical issue( my honda is civic ICDTI year of make 2007, diesel) but BOY it give me the creeps as soon as i switch off the engine as I constantly need to remove the battery cable in order I can go to work tomorrow morning how many fuses in the interior fuse have you got the issue with please let me know........ Better yet, maybe one of you can help me fix this problem.if faced with one yourself Thanks for reading /
Old Jan 22, 2019
GolNat's Avatar
Prelude Owner
Re: 10 amp fuse issue
Any circuit that is hooked into that fuse could potentially be causing the drain. Hook a current meter inline with the fuse and start disconnecting things until the excessive draw goes away. I would start with the easy stuff like the radio. Your mechanic should know what to do.
Old Jan 22, 2019
archi's Avatar
thank you very much indeed i will try and incorporate what you just wrote and deliver the message to the mechanic, even-though i had my car at three different mechanics*( they were saying change the battery even-though i did change the battery the problem kept repeating) it was Me i figured out recently from what i read on this forum regarding this type of technical issue? did you ever experienced such a technical glitch if i may ask...... thanks again for your reply
Old Jan 22, 2019
GolNat's Avatar
Prelude Owner
No I have been fortunate enough to not have that pleasure but I still have many years of automobile ownership ahead of me :-/
Old Jan 27, 2019
archi's Avatar
thanks man i have scheduled the service next week- been very helpful the forum and your reply much appreciated .............. any hidden gem of Honda car you wanna share that would be welcome the engine is very powerful but i recon to much electricity Honda uses no wonder it has many electrical glitches as i read on this forum
all the best/ take care
roverben
Jan 21, 2019 05:16 PM
Perfectionist
Apr 4, 2017 03:06 PM
Crizivan
Jan 6, 2015 08:52 AM
westcali_playa
19
Apr 9, 2009 02:56 PM
bobbyd
Dec 30, 2002 12:12 AM
