wiper issue
Old Sep 16, 2022
jcr0164's Avatar
jcr0164 is an unknown quantity at this point
wiper issue
I have 2000 civic lx and have issue with driver wiper, when it would go up would clean perfect but on down swipe it left a good id say 3in spot starting at top blade down that does not clear. I have replaced the arm and blade but a issue still persists, cleans perfect going up but down now a spot at center of blade id say 2inx4in strip starts about half way thru the down swipe to bottom. Ive tried old trick my dad taught me of cleaning windshield with purple power then glass cleaner thinking maybe just build up on glass but that didn't help. Anyone had this issue and know of a fix?
Old Sep 16, 2022
Re: wiper issue
bend the arm a bit
Old Sep 16, 2022
jcr0164's Avatar
Re: wiper issue
I was gonna try that but being a new arm figured maybe would be set correctly. Suggestion on maybe what spot on it should try bend? Forgot mention in first post i noticed if i put slight pressure against the arm with finger it would clear the spot on down swipe but soon as lift finger spot was back.
Old Sep 16, 2022
Re: wiper issue
out of curiosity, do you have a depressed spot in the windshield?
Old Sep 16, 2022
jcr0164's Avatar
Re: wiper issue
Not that i can tell from looking at it, but would think if did the area would have stayed same spot and not changed from top to middle. I can check it though to see, it has me baffled never had this issue on other vehicles.
Old Sep 16, 2022
Colin42's Avatar
Re: wiper issue
Does the linkage have slop? You can replace the bars in the linkage
JamesB
Exterior
Nov 15, 2021 03:47 PM
tabacivic
Electrical
Feb 22, 2019 08:05 PM
pratik05
May 15, 2015 01:54 PM
produo1
Mar 12, 2011 08:20 AM
Bo97EJ6
Mar 15, 2010 07:59 AM
